Browse Forums Building A New House 1 Aug 28, 2012 8:22 pm We are on the cusp of building our new home but have to have extensive site works done as our block is on a slope. Has anyone had experience with this? What should we look out for? Demo and site works 2Aug 29, 2012 10:53 am You will obviously need what is called a cut and fill to get a level base for building on. Check the muck away rate, and also the tip fees these can add up very quickly. Also depending which way the land slopes you may be able to use some of the excavation as fill material to save on tip fees. Try and get firm prices after your survey as provisional sums can change drastically. Also check to see if there are exclusion for hard digging and rocks within the quotes this can also add up sometimes. PPA 30/6/12, Land 28/06/12, Contract 7/9/12, Valuation 11/9/12, Prestart 13/9/12, Settlement 18/10/12, Building Permit Issued 18/10/12, Footings 30/10/11, Slab 31/10/11 Re: Demo and site works 3Sep 01, 2012 10:15 am Dale's suggested that it was going to cost an estimated 150k to do the site works on top of the demo of our current house and promptly washed their hands of the project as they are only interested in flat blocks with minimum works. Had another quote yesterday for 15 - 20K fof the same works. Too easy, apparently. Bizarre. Re: Demo and site works 4Sep 01, 2012 11:36 am Look at the plans and see the size of cut & fill. It is generally better to cut than fill because cutting will give you a solid platform to build your house. Fill soil is unstable and requires time & rain to settle. Contractor should compact soil in fill so they can build straight away. MBA and HIA both have sub contract agreements, check them out 2 7303 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4797 Fair Trading can issue orders to rectify and complete but once the matter goes to NCAT these orders are automatically vacated. You will have to terminate contract and sue… 21 29679 |
