Browse Forums Building A New House 1 Aug 27, 2012 6:45 pm I need to draw up some plans for a new part of our roof which involves using a 7.2 meter c section steel beam and steel posts, I was wondering if anyone has similar steel work in there plans that I could use for reference? Or any other source of reference would be grateful, cheers. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7031 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8472 |
