Browse Forums Building A New House 1 Aug 21, 2012 12:26 am I am looking at purchasing a block of land in Aubin Grove. It is basically rectangular with one of the front corners cut off on a 45 degree angle due to it being in a cul de sac and a lane way. Who do i contact to find out information on what the building setback requirements are from the street. Is this a local council regulation or does it have to do with services (sewerage, power, etc)? Any help would be greatly appreciated. Re: Street/building setback 2Aug 21, 2012 5:49 am Setback requirements are a council issue. Services usually affect either the side boundaries or the rear boundary and are shown as Easements on the title plan. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Street/building setback 3Aug 21, 2012 8:53 am Evolution1 I am looking at purchasing a block of land in Aubin Grove. It is basically rectangular with one of the front corners cut off on a 45 degree angle due to it being in a cul de sac and a lane way. Who do i contact to find out information on what the building setback requirements are from the street. Is this a local council regulation or does it have to do with services (sewerage, power, etc)? Any help would be greatly appreciated. Contact the City of Cockburn.... they will help you out and give you all the info over the phone Good Luck Re: Street/building setback 4Aug 21, 2012 11:45 am Alternatively, the selling agent or the developer should have a copy of the DAP which should contain this information (if you have difficulty getting in contact with someone at City of Cockburn). It's finally happening! Follow our build with Homegroup WA viewtopic.php?f=31&t=55324&p=987698#p987698 Street/building setback 5Aug 21, 2012 11:58 am Usually it's an average they use a calculation based on your plot. For example I have a corner plot in Waikiki and asked for it to go as close to the front as possible. So my house has been drawn to sit an average of 6m back however the garage sits forward and is only 4.5m from the front. It's done on how much space you have at 3,6 & 12m from the front of your block. Phone planning at the council they will tell you. You can then tell your builder where you want the house otherwise they will put it 6m back as a rule of thumb. This is particularly important if your planning a pool etc out the back. PPA 30/6/12, Land 28/06/12, Contract 7/9/12, Valuation 11/9/12, Prestart 13/9/12, Settlement 18/10/12, Building Permit Issued 18/10/12, Footings 30/10/11, Slab 31/10/11 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3666 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15767 |
