Been told that you need to water your slab with the hose while it's drying to stop it from cracking...
Can someone comment on that? Is it necessary to do or not?
Thanks
Browse Forums Building A New House 1 Aug 17, 2012 12:37 pm Been told that you need to water your slab with the hose while it's drying to stop it from cracking... Can someone comment on that? Is it necessary to do or not? Thanks Re: Watering Your Slab... 2Aug 17, 2012 12:53 pm AubinGroveFan Been told that you need to water your slab with the hose while it's drying to stop it from cracking... Can someone comment on that? Is it necessary to do or not? Thanks Doubt it. Otherwise you'd see a lot of the kit-home companies coming by to water the slabs they lay (after all a 7 year warranty is a long time...) Masterton Villina 36 - 2011 Jul-SLAB Aug-FRAME Nov-BRICK+ROOF Dec-INSUL Jan-GYPROCK Feb-LOCKUP Mar-PCI Apr-KEYS+MOVE May-Driveway+Landscaping Blog - http://new-lindfield-house.blogspot.com.au/ Re: Watering Your Slab... 5Aug 17, 2012 1:31 pm In Perth , perhaps not in winter, tho I still would. In Perth in summer, absolutely. Soak it , then soak it again. You feel and look like a moron watering concrete, but ask the guys that pour it, the longer it takes to cure the better. Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: Watering Your Slab... 6Aug 17, 2012 2:00 pm The longer it takes to dry the better. Curing is different to drying. If concrete dries to quick it can shrink and crack because the concrete hasnt cured enough and is not strong enough to resist cracking. Re: Watering Your Slab... 7Aug 17, 2012 2:44 pm jo&waz AubinGroveFan Been told that you need to water your slab with the hose while it's drying to stop it from cracking... Can someone comment on that? Is it necessary to do or not? Thanks Doubt it. Otherwise you'd see a lot of the kit-home companies coming by to water the slabs they lay (after all a 7 year warranty is a long time...) Contracts signed from Feb 2012 in NSW it is only a 6 year now Re: Watering Your Slab... 8Aug 17, 2012 3:43 pm I hope we don't have to water it as we have no water in our estate! Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16420 4 6269 The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5272 |
