Browse Forums Building A New House 1 Aug 16, 2012 2:13 pm We are in the process of designing our new house....just wondering if anyone has used a new flooring system with concrete on a second floor, apparently approx. 50mm of concrete poured over special flooring. This process is instead of a suspended concrete slab and more economical. It has been suggested by our architect but need to research? Cheers... Re: Polished concrete floor on second story of house 3Aug 18, 2012 9:13 am Why can't the architect do the research? I thought that was what you paid them for? Anyhow I agree that the weight may cause an issue even if it's not a "real" concrete slab. A blog about our renovation http://notmynightmare.blogspot.com.au/ Re: Polished concrete floor on second story of house 4Aug 18, 2012 10:36 am Not sure what flooring system you are referring to instead of a suspended slab but one that is used in WA is called FloorTech and it is a truss system with the slab poured on top. All of the ground floor lights and services are run through the trusses.... Lots of builders use this approach over in WA. Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8500 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4098 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 |
