Browse Forums Building A New House 1 Jul 31, 2012 9:57 pm we seem to have had a mishap, and our plumber has had to move kitchen sink pipes, and cut into our slab and tried to cover it up. I have been told that warranty can be voided, and have no idea why this was done and whats goig to happen. Can any one shed some light on the matter?Thanks Re: plumber error? Slab has been cut into? 2Aug 01, 2012 2:59 pm Can't answer your questions directly can only tell you what happened to us. Our slab was cut into (about 20cm x 20cm) as they forgot to put a 's' bend in for future shower (otherwise it was just a normal capped point). They then had to put granite guard (?spelling) into the area where the slab was removed, before putting concrete over the top and then sealing with a waterproof black substance. This ensured that termites and water couldn't penetrate. In your situation, It may depend on whether they had to cut all the way through your slab or just hollow out a section. Do you have any pictures? How far did they have to move the pipes? What did your site supervisor say? Never argue with an idiot they drag you down to their level & then beat you with experience - Dilbert View Thread: viewtopic.php?f=31&t=19733 Contract signed 14Sept Slab 30Sept Bricks laid 1Dec Lock up 26Feb Keys 10Jun Re: plumber error? Slab has been cut into? 3Aug 05, 2012 12:14 am Depending on the size, location and depth of the cut/ hole. Then depending on the way it was re filled. Was additional rio bar installed and tied in, were additional bond chemicals used. It may have just been to bring a pipe through and has only been cut into the top 100odd mm without breaking slabs reinforcement layer. Asking the relevant building surveyor if they are aware is also a good starting point Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72346 Ask yourself if the insurance company will be aware of the Reno. 4 7385 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18830 |
