Browse Forums Building A New House 1 Jul 30, 2012 8:05 am We just had an independent inspector inspect our house at frame stage and he gave us the report this weekend. Are these defects "normal", as in common oversights etc? -Enviroseal around the house has not been taped properly and is not sitting flush with the house, there are gaping holes where pipes has entered the house through enviroseal. This affects the energy star rating of the house. -2 places with 3cm gap between concrete slab and wooden frame. -Missing timber blocks at wall junctions. -Timber nogging located in north wall of room within the northeast front corner of the room is crooked not complying with requirements of AS1684-2 Residential Timber Framing construction manual – recommend straightening this nogging. -Timber wall stud located at vanity waste pipe & vent pipe has been cut down. This stud is required to ensure adequate support of the top wall plate & roof frame at this location. Unfortunately this timber stud is not salvageable & will need to be replaced & relocated further to the RHs of the waste pipe & vent pipe to ensure that this timber stud has adequate bearing onto the concrete floor slab to ensure correct top plate & roof support at this location. Replacement & relocation of this timber wall stud will require modification of plumbing / water supply lines & water supply points that have already been installed at this location. Have already sent the report to the builder so awaiting their reply. They have started bricking this weekend so hopefully, they won't work too fast to cover up the mistakes! oh and what is up with the huge gaps between windows and frames? I trolled through the forums and it seems that lots of people have this and the inspector didn't pick up on it, so I thought it wasn't that important? Inspector says that is fixed at brick stage but won't the windows itself, not secured by the frame, have a bit of movement? Are these defects important? 2Jul 31, 2012 10:04 am I'd be interested to hear an answer on this too. I'd be asking the independent inspector though... No point having a report but not knowing what to do with it! Good luck with the rest of the build. Re: Are these defects important? 3Aug 01, 2012 10:10 pm i dealt with the builders during my parent's build last year and I noticed gaps between windows and frames on some of the windows (especially on those high and long rectangular windows). I also thought that this was odd, however was told by the builder that it was normal and then had brother who is a bricklayer also told me that its common and not to worry about it. Building the Oasis 27 in Mernda Re: Are these defects important? 4Aug 02, 2012 8:45 pm fuzzy-sizzles i dealt with the builders during my parent's build last year and I noticed gaps between windows and frames on some of the windows (especially on those high and long rectangular windows). I also thought that this was odd, however was told by the builder that it was normal and then had brother who is a bricklayer also told me that its common and not to worry about it. They don't have the bricks touching the window frames for a reason However, the defects mentioned above all sound like problems that you would want fixed. Unless the builder can provide a very good reason why it doesn't need fixing. Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and… 0 2475 The worst thing you can do is sign a building contract without a pre contract review. Over the years many people have come to me with disputes where they just signed… 0 8351 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6919 |
