Browse Forums Building A New House Re: Things you forget 141Oct 30, 2010 9:33 pm We're having a custom design and build, and thanks in part to this thread, we've remembered most things. But I am Terribly Sad that I didn't think to ask for our doors to be rebated (in this case, rebating is when you cut out a bit of the slab so that the door sill is flush with the floor). We have high sills on all external doors, which is particularly galling when we went to the trouble of putting a ramp in for ease of wheelchair access. I even (way before design even started) bookmarked a photo of a flush floor, door sill and deck, but then it completely fell out of my head. It simply didn't occur to me that this wouldn't be standard. I foresee many trips for first time visitors, just hope nobody really injures themselves. Can't remember if anyone mentioned skirting boards and architraves? And solid core doors? (so little extra cost wise and such a huge boost in the sense of a home's solidity) And really good house numbering? (this can make a difference in how soon an ambulance can find you) We have a void over our bathroom that's going to have an indoor clothesline. And we have a solid wall (E0 mdf) under plasterboard where we thought we might want to have wall hung cabinetry and shelves in our lounge. And powerpoints in medicine cabinets and/or vanities for plugging in electric toothbrush etc (make sure these can't fall in the sink though!!!!). In one or two other cases, what I had in mind and what the builder had in mind have turned out to be different things, and in many others, if I hadn't been such an opinionated control freak, we would certainly have ended up with the builder's default setting, which would not have been good. I have an evolving checklist in a spreadsheet. I will tidy it up and see if I can post it. I have gotten a bit slack about documenting things, and whilst nothing has gone terribly wrong, it has made me feel vulnerable. So my final suggestion: get yourself an exercise book and use it to diarise every verbal communication and agreement. If you communicate via email, print them all out and shove them in a folder and/or make sure all emails are backed up!! e. Re: Things you forget 142Nov 01, 2010 9:07 am <deleted by user - off topic> Building at Warner Lakes in sunny Queensland. Building with Bold Properties. Building thread is here! - https://forum.homeone.com.au/viewtopic.php?f=31&t=38957 Blog is here! - http://campoutforland.blogspot.com Re: Things you forget 143Nov 01, 2010 9:29 am higherdestiny Pugs Unless you are a Data cabler or you are an Electrician and have your Open or restricted cabling License/ Ticket it is Still Ilegal for you to run your own Network and telephone cabling. Really? Do you have a link or similar to back that up? Of Course I do. http://www.acma.gov.au/WEB/STANDARD/pc=PC_1685 higherdestiny I was under the impression that network cable was unrestricted - especially if running through pre-installed conduit ducts. Update - Just spoke to an electrician friend of mine who stated that you can wire Cat6 for internal network use without a ticket - so long as that network doesn't connect directly to the telephone system. The Cat6 network can even connect to a switch which is also connected to an ADSL modem or similar without violating this restriction, but it's not directly connected to the telecommunications network as such - data from the telecomms network is simply routed into the internal network. No Offense yo to your mate but does he have his data ticket? higherdestiny "All cabling work, including telephone, data, fire and security alarm systems cabling, that connects or is intended to connect with the telecommunications network must be performed by a registered cabler, or under the direct supervision of a registered cabler." The rule is in place to prevent novices from screwing wiring directly attached to the exchange and causing interference with neighbours connections etc But an internal network (even if connected to an ADSL modem) is OK to DIY. You cannot however cable your own telephone lines, smoke detectors or alarms. Nor can you run Cat6 if it directly connects to the telephone system (via patch panel, for example) Confusing, but my electrician is confident that an 'isolated' (separated from direct connection to telephone) cat6 network is OK. As is running your own speaker cables, HDMI etc. Anyone care to confirm? It isn't Isolated tho... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Things you forget 144Nov 01, 2010 8:23 pm ..And when you sell and the next person connects it up to be part of a network/uses it as part of their phone system? No longer isolated. And if they are smart and demand the legally required data certified installers details before purchase? If it has the ability to become connected it must be installed by someone with a data ticket. So.. data, think about where and how before your build starts and your contract is signed. . Re: Things you forget 145Nov 02, 2010 9:09 am THIS IS ALL BECOMING OFF TOPIC If you wish to still talk about it ... please start a new thread. This has been a very useful thread to a lot of people, and would be a shame to ruin it now. We're building The Albany 330E with Casa Design & Construction via National Builders Group See how we are going here: https://forum.homeone.com.au/viewtopic.php?f=31&t=32694 Re: Things you forget 146Nov 02, 2010 8:16 pm Guys, A very common thing to do is install Junction boxes to run outside lights, I have a few sparky mates and one of the suggested running downlights under the eves, you can apparently run 5 downlights for the same power usage as 2 exterior lights. Looks wicked too! Re: Things you forget 147Nov 02, 2010 9:58 pm Hi everyone My suggestion is to take photos at frame stage after the electricians and plumbers have run their pipes (if possible, I know a lot of owners may be locked out). Today we installed a number of floating shelves in our kids' rooms and had to work out whether there were any electrical, phone or other wires behind the plaster. Although we were pretty confident there weren't, my hubby had to get into the roof and check just to make sure. So if you can, go into EVERY room and take a photo of every wall, as well as above the roof plaster if you can. Even though you may think you've planned everything, you may want to add something in the future that requires you drilling into the wall. I know there's a lot of walls, but once it's covered with plaster it's hidden, and memories don't count for much when it comes to needing exact placement. My apologies if this has been added before - I didn't have the time to read through all the past pages. J-A Re: Things you forget 148Nov 05, 2010 7:30 pm We have three things: 1. Drainage for your backyard - our builders didn't suggest anything and we forgot to mention it so poor DH spent a few hours digging up the backyard hooking drains up to the downpipes! Would have been far easier to include it in the plumbing quote!! 2. Soft close drawers - I think this has been mentioned. We completely forgot and I have 17 drawers in total on my kitchen. They definitely would have been better than the constant sound of slamming of my drawers. 3. Refer to pic - I would suggest placing the powerpoint on the side wall tile, this way you can put something pretty in the corner, like a vase or something!! Re: Things you forget 149Nov 08, 2010 2:42 pm Hey n&n02 We were quoted something ridiculous for soft-closing drawers sp dropped it. However, try Tim & Tina on this link as he has found one you can fit yourself easily.... http://www.tim-and-tina.com/ Re: Things you forget 150Nov 08, 2010 4:26 pm OurLindrum52 We were quoted something ridiculous for soft-closing drawers sp dropped it. However, try Tim & Tina on this link as he has found one you can fit yourself easily.... http://www.tim-and-tina.com/ Wow thanks for that!! I’ll definetly show my husband, they look really good! I also thought of more stuff - sorry if some of these have already been mentioned: 1. Extend your garage if possible. We only extended ours to 6m x 6m and it makes all the difference. Possibly consider adding a storage/workshop space as well. We are so glad we did – clears all the clutter away from the cars. 2. Got a front loader washing machine? Consider running your laundry bench the whole way across your laundry. Makes the laundry look more neat and streamlined and I love the extra bench space for folding clothes etc. 3. I added a clear space of 450mm in my laundry to hold a clothes basket. Don’t forget to tell the tiler not to tile this space! We forgot to mention it to the tiler and this space was tiled with skirting tiles so DH had to trim my clothes basket to fit to accommodate the extra width of the tiles layed in that space. 4. Check your building specifications Contract and see what it states about skirting for your tiles. Most builders use your floor tile as the skirting tile and only tile skirting to 200mm. If you want full height skirting, you may have to buy these extra as (imo) full height skirting looks better. 5. Perhaps include a letterbox in your building contract. We only paid $250.00 for ours (brick, rendered and painted) and it was well worth it for us. If you’re thinking of using the leftover bricks and constructing one yourself after handover, possibly consult with your ss or builder to leave leftover bricks on site. All our bricks were taken away from site when bricking had finished and I think a few others have mentioned the same thing happening with their bricks. 6. Having your builder install a wall mounted clothesline for you? Check the measurement they have given you as our builder upgraded ours to a further 1m long and it was the same price as the smaller one. 7. Keep a diary or spreadsheet of all your dates (e.g. slab pour, frame delivered, frame started etc, etc) once construction starts. You don’t know when you will need to refer to it if something needs to be brought to the attention of your builders. Also keep a diary of dates and notes of phone conversations with builders/ site supervisors etc. 8. I also kept a spreadsheet of all costs paid and money spent associated with the build. You can then easily track exactly how much you have spent on your build overall , where your money has gone and if you need to refer to it, the date it was paid. Re: Things you forget 153Nov 11, 2010 9:52 pm Got Tender tomorrow, so figured this would be a good time to go back over the list. I'm pretty sure I forgot to include a solid door to the Xbox room. Shall write that down now Land Deposit - 18/12/2009 Became a land Baron - 21/12/2010 Site Start - 27/1/2011 All moved in!! Re: Things you forget 154Nov 12, 2010 8:52 pm A bit of a bugger, we just realised....we are installing a auto opener for our garge after handover and forgot to get the builder to put in a power point on the ceiling. we have a flat roof and is going to be a headache to get to it now! Re: Things you forget 155Nov 12, 2010 9:06 pm Ok,have just realized on plans that pantry door opens in. Not good,because you would have to close the door to get in behind it/to get to the rest of the pantry,DOH! Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Things you forget 156Nov 13, 2010 12:07 pm HI all If you are a photographer or just love lots of wall hanging get them to put in an extra row of nogging so you have a solid row of wood to hang to, not just plaster. Put in as many power points as you can and TV points its cheap now than latter. I would also recomend you do a lot more planing before you even think about building a house. KW........ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Things you forget 157Nov 13, 2010 5:57 pm With the electrical, i'd suggest also adding a conduit for whereever your foxtel is going. If it's on a cavity wall then they normally have no problem but if its not then it can be a pain. Add the conduit so they can run a TV and Phone cable down. The other thing, while wireless is OK nothing beats hard wired internet. Get CAT5 cables to all rooms that may need data points. Also, run 2 x data points from your main living area to all other areas that have a TV (so you can later introduce a LEAF video distribution system - or something like it). RE; the fridge tap - don't put the tap directly behind the fridge, put it inside the kitchen cupboards instead and just cut a hole for the water line later. Putting the tap and filter behind the fridge often won't let the fridge fit. Also, check measurements of your furniture etc.. (fridge is a good one) and make sure you allow 12mm for render on the walls AND make sure you allow for your floor coverings!! I've seen people have an 1800mm high fridge and look at the plans thinking it's OK, only to find they put plank on ply timber floors and the distance ended up being 1755 from the floor to the overhead cupboards. Re: Things you forget 159Nov 14, 2010 9:34 pm YBBroker - good point re tap behind fridge! Does anyone know how much space a tap will take up? We have a reasonable fridge space but I'd rather get it right before no more changes can be made to our plans! Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Things you forget 160Nov 15, 2010 12:23 pm and can that tap be fit not exactly behind the fridge but on a bit side - in same space as fridge goes in but in the sort of corner as there is normally some space between the side wall and fridge - i hope it makes sense what i am writing Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11865 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8582 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6823 |
