We're having 3122mm x 1200mm island bench however in our NHP (new home proposal) it says:
A join may be required in the bench top and will be located as per suppliers recommendations.
I have requested with our CSR to indicate in the NHP that the Client is requesting no join. I was told that they cannot omit that wording as it will depend on the bench length as well as the supplier's availability during that time.
Can anyone please advise? Have you also requested no join on island bench in your NHP?
I don't want to risk it as I may end up having an island bench with a join.
Thanks
I’ve always read that anything over 3m has to have a join. Can you reduce bench to 3m if you really don’t want the join?
Thanks shokel1975, I thought a 1 piece of stone is 3200mm in length. I'll check with them and reduce to 3m if it's the maximum. Should I still request them to indicate no join to make sure?
I would just to be sure. You never know with these builders what you will get if you simply ‘assume’. Lol
