Browse Forums Building A New House Re: Things you forget 169Nov 24, 2010 12:16 am Jason Building a modified Platinum MKII with Blueprint Homes. House Plan Contracts Signed: 18/10/2010 Prestart 21/10/2010 Sandpad: 14/1/2011 Slabbed: 27/1/2011 Brickwork: 15/2/2011 Roof: 18/3/2011 Re: Things you forget 170Nov 24, 2010 11:16 am Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Things you forget 171Nov 24, 2010 12:56 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Things you forget 172Nov 24, 2010 1:01 pm Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Things you forget 174Nov 24, 2010 11:36 pm Jason Building a modified Platinum MKII with Blueprint Homes. House Plan Contracts Signed: 18/10/2010 Prestart 21/10/2010 Sandpad: 14/1/2011 Slabbed: 27/1/2011 Brickwork: 15/2/2011 Roof: 18/3/2011 Re: Things you forget 175Nov 25, 2010 10:05 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Things you forget 176Nov 25, 2010 10:54 am Pugs Boardband avalibity! not the most common thing to check for when building a house .. but it should be. unless you are moving into a FTTH estate or a (current) NBN roll out area.. it is one of the most ovelrooked services for home builders. just because you can get Dial tone this doesn't mean you can get any form of ADSL. hows does one check this: Ask your new Nieghbours.. or check this site : http://yourbroadband.com.au/ Definately this!! My sister just moved into her brand new home in Wyndhamvale's Manor Lakes estate and has found out that the only option they have for internet connectivity is wireless. She isnt very happy... Re: Things you forget 177Nov 27, 2010 6:41 pm Thanks for all your wonderful tips, it has been such a help to us, being about to build our custom designed home. One thing we were advised to do was have a drying cupboard eg a duct put in a cupboard that is only used for drying clothes Re: Things you forget 178Nov 29, 2010 2:49 pm Bumping this. This is simply an invaluable list. Wonder if it is possible to have this thread stickied and even better would be a short simple listing on the 1 page. Stuff we found to be useful and easily overlooked. Privacy locks esp on the guest bathrooms. capped water point & power points to the roof if you are intending on evaporative cooling installed. My Baby Hartley initial deposit 7th Aug'10 Signed contract 4th Dec'10 site start as per contract 25th May'11 slab pour 22nd Jun'11 Re: Things you forget 179Nov 29, 2010 5:16 pm S_Loke Bumping this. This is simply an invaluable list. Wonder if it is possible to have this thread stickied and even better would be a short simple listing on the 1 page. Stuff we found to be useful and easily overlooked. Privacy locks esp on the guest bathrooms. capped water point & power points to the roof if you are intending on evaporative cooling installed. this thread is already stickeid.. it is just when one of the other stickies threads gets a new post it drops down to the postion down inthe stickied list Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Things you forget 180Dec 05, 2010 10:22 am Love all the tips. We increased the length and width of our BIR where possible. Standard width was 500mm, we increased to 600mm, still probably not quite enough, but better than 500 which will definitely catch on clothes as we shut the doors. Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11647 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8422 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6635 |
