Browse Forums Building A New House 1 Jul 21, 2012 3:54 pm Checked out progress of building this morning and noticed water seeping through slab onto garage floor. Garage floor is lower than ground floor of house but surely water should not be getting through- it is pretty wet at side of house and there is no drainage yet so somehow water is flowing under house slab and seeping in to man cave!! not good -- does anyone have any ideas whats gone wrong?? please help Re: water seeping through slab 2Jul 21, 2012 9:58 pm no idea, sorry, but I too am fearful of water seeping into our slab (we have permanent pools of water around our garage slab, with gaping holes appearing in the earth under the slab, that I am sure it is just a matter of time)... so will be interested in any responses... (ps: I did ask the independent inspector about the cave looking gaps under our slab at the back of the garage, but he said they were fine and when we move in to put a concrete perimeter around the slab...). SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: water seeping through slab 3Jul 21, 2012 10:36 pm have they hit a spring when clearing the block of land to put the slab down Re: water seeping through slab 4Jul 22, 2012 7:52 am thank you for replies zahira--dont think there is a spring, when it was excavated rain water would lay around site but dried up fairly quickly, whereas now the house is nearly complete water just pools at the side and doesn't dry for ages. I suspect thats where the problem is coming from. sunshine - I'm hoping a concrete perimeter sloping away from house will fix my problem. That should sort you out too sounds like you have an erosion issue maybe? Re: water seeping through slab 5Jul 22, 2012 8:41 am yes, hoping so. We definitely have an erosion problem, which has been partially plugged with concrete. But we are planning on a concrete perimeter sloping away too. It is just during the build that I have been concerned about... Fingers crossed for you too... Have you thought about getting an independent inspection done? SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: water seeping through slab 6Jul 22, 2012 8:56 am hi sunshine monday morning phone will be running HOT, will call inspection guy and site supervisor will update with results. Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18806 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7324 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38448 |
