Browse Forums Building A New House Re: Shower Niche help- single brick; can it be done? 21Jul 21, 2012 9:05 pm delatite the wall I prefer the niche on is internal, but apparently in WA they don't use wooden stud frame? GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Shower Niche help- single brick; can it be done? 22Jul 21, 2012 9:13 pm Hi turtleschell So are your internal walls brick then ? Or what are they constructed of? If brick, still not a problem, since they haven't been constructed yet. Just need a small lintel above the cavity (engineered of course) It's then simply lined with cement sheet or similar, then waterproofed same as normal stud frame niches. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Shower Niche help- single brick; can it be done? 23Jul 21, 2012 9:33 pm The internal walls are made of brick, yes. Hmm, ok so at prestart I will demand the shower niche! This is a relief, I will update with the result after prestart next wed! GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Shower Niche help- single brick; can it be done? 24Jul 21, 2012 9:52 pm Anything is possible, as it hasn't been built yet so they don't have to deconstruct to accommodate it. The brickie can simply install the supplied lintel (by your builder), and brick the opening accordingly, just the same as they would in any other doorway, window or other opening in the bricks. Then your plasterers will simply line the cavity....insist on cement sheet/villaboard or similar as it is thinner and more waterproof than WR (water resistant) plaster. The builder will probably whinge a bit because of the change, just remember, they shouldn't charge you the earth for it, it's a really easy simple change for them. Good luck Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Shower Niche help- single brick; can it be done? 25Jul 22, 2012 11:45 am Yeah its not all bad news if its an internal brick wall. Not being from WA im not sure if the walls are common brick or blocks, either way there is plenty of depth for the shelf, and the width and height can be anything. It doesn't matter what they line it with so dont get caught up with that. Cost wise you will pay what you pay, there is extra work in it for the brickie, plasterer, waterproofer and tiler. If your builder is someone who doesn't like putting them in for what ever reason, then you will pay the "if they want it they can PAY for it price" I guess the main thing for you is, yes it can be done. Cheers mgilla Shower Niche help- single brick; can it be done? 26Jul 22, 2012 5:17 pm They can be done in wa, I've got 2. For both we had an extra cost to build a double brick wall on what would normally be a single internal wall. Even where the shower was on an external wall, they still added an extra layer of bricks to accommodate the niche. I don't k ow how much it cost off the top of my head but it wasn't too much and I LOVE my niches. my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Shower Niche help- single brick; can it be done? 27Jul 22, 2012 8:31 pm Hmm so are we looking at structural change then? :/ GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Shower Niche help- single brick; can it be done? 29Jul 22, 2012 9:54 pm Dave in the Hills, beechwood only charged us $300ish for the shower niche. I think that is for 45cmx45cm. Building The Verdelho (modified) At The Ponds Contract Signed - 30 November 2011 Re: Shower Niche help- single brick; can it be done? 30Jul 22, 2012 10:29 pm As above a flat bar or a "inverted "T" depending what they want. Keep your size and location to try and match the size of your tiles. Just a lot easier. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Shower Niche help- single brick; can it be done? 31Jul 22, 2012 10:50 pm My sales rep told me they'd have to build another wall too (and coz my bathrooms are pretty tight fitting, it wouldn't work) so I guess I'll have to see what they see at prestart. i mean, if they don't want to do it, even if it's simply against the plaster of the next room, they simply won't. Maybe they are concerned about water leaking through the waterproof membrane/gyprock into the next room? GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Shower Niche help- single brick; can it be done? 32Jul 23, 2012 7:51 am avonst Dave in the Hills, beechwood only charged us $300ish for the shower niche. I think that is for 45cmx45cm. Good to know. Perhaps I got my numbers wrong. Beechwood have been very reasonable about everything else. EDIT: - wait is that for 1 or 2? I think my $600ish figure was for both the bathroom and ensuite. Shower Niche help- single brick; can it be done? 34Jul 24, 2012 12:54 pm People, it's a whole different kettle of fish here in wa. Brick walls, no gyprock, no frame. In a single brick wall (which is what most internal walls are) there is just no way to have a niche. Gotta be double brick, but it only changes the room slightly, see if you can get them Both on the same wall so you only Have one extra thick wall. Yeah it was a structural change but so worth it! my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Shower Niche help- single brick; can it be done? 35Jul 24, 2012 2:23 pm tinkster noooooo you have confirmed my fears. I wish I'd demanded the shower niche's before. It'll be at least $350 for the structural change, plus more bricks, and I want two niches.. You definitely think well worth it? :/ I really love them but i have SO many upgrades.. GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Shower Niche help- single brick; can it be done? 36Jul 24, 2012 2:26 pm Building in Perth with Ventura,having niche in single brick walls,$400. All they did was put an extra layer of bricks to the wall with niche,they said they could not do it but i pushed,finally said ok No structure change needed,they built the shower & then did the walls n niche. Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Shower Niche help- single brick; can it be done? 37Jul 24, 2012 2:28 pm Could they build a sml wall,say just the width of the niche. Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Shower Niche help- single brick; can it be done? 38Jul 24, 2012 3:14 pm kerry ann - $400 for ONE niche? but no structural change? Did you do it after contracts? I'm wondering if they can just add the extra layer of bricks IN the shower only. GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Shower Niche help- single brick; can it be done? 39Jul 24, 2012 7:00 pm Hi,yes $400 but i really wonted them,as i said i had to fight for it though. Re just adding the extra bricks in the shower,yep thats what i was saying,ask them. I am going to have to think back on if it was after contract but i dont think it was The thing with our house is that Ventura has not built these sortta homes before & i'm glad they changed their minds. Going to have to see if i have a photo,i'm sure i have,will take acouple of days as i have to swap from lappy to putta & all my kiddies are home now,no quiet thinking time,if i cant find one i am due for a visit out there soon & with take one then & you can see how they did it. Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Shower Niche help- single brick; can it be done? 40Jul 24, 2012 10:14 pm So I gather that in WA no one has plaster walls Everyone has exposed brick walls? I would assume that this is not the case, and whether it be solid plaster, or gyprock sheeting I fail to see how a niche cannot be installed in a single brick wall. Seriously it really is not rocket science. Given that a standard brick is approx 110mm wide plus some type of plaster, unless and exposed brick wall, this will equate to about 120mm without the shower side. I fail to see how a lining cannot be placed inside the niche and waterproofed to make it sound enough to lay a tile on. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15244 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11596 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8152 |
