Browse Forums Building A New House 1 Jul 19, 2012 5:33 pm Hi, My boyfriend and I are building a Dale Alcock house in Madora Bay and the Developer H&N Perry won't approve a very small area above our portico to be timber cladding. Is there any way around these covenants? There are so many in the area already with timber cladding which we took photo's of and sent to the Builder which they emailed but the response was simply: "I am aware of other houses around Madora Bay with cladding. Some of the original stages at Madora Bay had different covenants on them and some of the houses do contravene the covenants. There is nothing we can do about that. It is up to the other owners on the deposited plan to enforce any restrictive covenant. However, as previously advised, we are unable to approve any plans that contravene the covenants". Please help! I recently hit a snag with my new build with Metricon. On the block I purchased there is an old covenant when the land was subdivided in 1971 that "the exterior walls of… 0 1969 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16076 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12147 |
