Browse Forums Building A New House Re: Builder issue with drainage. 2Jul 16, 2012 5:57 am Issues like this are hard to get to the bottom of particularly in a forum like this but...... Unless you have very high water use on your meter I would suspect its a drainage issue. As water can travel easily along service trenches it quite often can concentrate at one point. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Builder issue with drainage. 3Jul 16, 2012 7:39 am You say this is a new home and the drainage is the problem. WHY? The first step is to determine if design and construction is adequate because this should not be happening. Any dealings you have and any inspection reports should be in writing If you are getting nowhere with the builder you will need professional help Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 2868 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12212 2 5811 |
