Browse Forums Building A New House 1 Jul 12, 2012 7:22 pm Hi All, in our new house we had planned to have all our dgpos at 150/200afl so that they don't clash with bed frames (@200afl) or other furniture when we push these against the wall. However, we've just learned from our builder that that's not possible as 'the drill is not long enough', and we need to have the dgpos at 300afl. This doesn't make sense as the only distance that increases by going from 300 to 120 is the distance to the ceiling, and I don't think they drill down from the ceiling with a single drill bit. So I'm not quite sure why the drill length matters when changing the height of a dgpo. Or is it rather the cut-out for the conduit that can't go that low? Could someone please enlighten me what the situation is? Is there a legal requirement on the height of the dgpo? Or is there a technical limitation to how low the dgpo can be positioned? It would be good to know all the background before I start arguing with the builder. Thanks for any help, Tom PS: The exact wording is: "All dgpo's must remain @300 afl or higher due to maximum length drill can reach through brickwork" ~~~~~~~~~~~~~~~~~~~~~~~~ Building with Redink in Madeley WA Photos: http://s1244.photobucket.com/user/takat ... yHouse2012 Moved in 01/06/2013 Next project: Lanscaping Re: dgpo height afl 2Jul 13, 2012 5:43 am That sentence appears nonesensical. I fit 300 high as a standrad but there is no regulation in the wiring rules. Ask for a further explanation @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10657 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7712 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 |
