Browse Forums Building A New House 1 Jul 09, 2012 10:38 am Hi all, We are in the progress of demolishing and went through council's asset protection process. We found out yesterday that 2 slabs of the conrete on the footpath has been cracked by the demolishing truck. Council mentioned they will charge $500 per slab. Are we able to get a concreter to fix it up ourselves or do we have to go through the coucil. It seems rather expensive. Cheers Re: Help needed footpath cracked 2Jul 09, 2012 7:39 pm No, you can definetly fix it yourself and it is a reasonably simple job to DIY @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Help needed footpath cracked 3Jul 09, 2012 8:09 pm Just don't fix it until the building work is finished The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Help needed footpath cracked 4Jul 10, 2012 12:10 am depending on your council they may want to fix it asap or ask you to fix it asap as there is a liability if it is cracked and someone trips on the crack there could be a law suit. I would make sure whatever you do you ensure that the council are aware of it and the time frame you want to do it in. Re: Help needed footpath cracked 5Jul 10, 2012 9:50 am I thhink we need to fix it before the building start as Henley will apply for another asset protection. Its cracked quite badly so not sure if we can DIY as I am unexperienced but we may be able to get away with it with a cheap concreter. Fingers Crossed Thanks for all the response guys. Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20189 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8914 |
