Browse Forums Building A New House 1 Jul 05, 2012 11:15 pm Hi everyone, Just wondering if anyone can recommend a good company to use to inspect my house and make sure everything has been completed correctly? I'm in WA and NOR. Thanks! Custom build Perth Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=44112 Purchased block: May 2009 Building approval: July 2011 Bricks complete: Jan 2012 Re: Recomendations for PCI inspectors in WA NOR? 2Jul 06, 2012 11:31 am OMG, I just read your build thread :/ I am using BCI firth at the moment, we have had two inspections done so far. The prices are very reasonable and our inspector Stuart Blackie seems to really know his stuff and is always on time. We werent present for our roof inspection, but my partner was there for the plate height inspection. He took his time going over the door frames with a level, measured some of the rooms etc. Re: Recomendations for PCI inspectors in WA NOR? 3Jul 06, 2012 12:45 pm Hi I'm also building in Perth...thanks for the info...can you advise what costs are for BHI Firth per each stage? Anyone tried BSp or Houspect? Especially for a double storey? I have also got quotes from Houspect and BSP and approx - for ALL stages on a double storey house - Houspect was about $2,500 after RAC discount while BSP was $3,600. I think I know which way I'm leaning on a tight budget... Re: Recomendations for PCI inspectors in WA NOR? 4Jul 06, 2012 2:01 pm Thanks alt0160, will give them a call. And yep, you can see why I want an inspection. Dexter I sent off an email to BSP and gave them house size and details of the build etc and they wouldn't give me a quote until I told them what suburb I live in! Made my alarm bells go off straight away because in my mind, the suburb shouldn't be relevant. Custom build Perth Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=44112 Purchased block: May 2009 Building approval: July 2011 Bricks complete: Jan 2012 Re: Recomendations for PCI inspectors in WA NOR? 5Jul 06, 2012 3:38 pm The person who recommended BCI to me used housespect previously and wasnt particually happy. This is the cost sheet that BCI sent me for a single story house. You will need to contact them to get an updated quote. We didnt engage their services until plate height Quote: Slab down: $350 inc. GST. 1. Dimensions of slab 2. Positions of step-downs for tiled wet areas 3. Positions of plumbing penetrations in slab 4. Condition of slab surface (smoothness, cracks, etc) Plate height: $450 inc. GST. (Two storey properties may require an additional inspection on the 2nd storey plate height) 1. Check building dimensions against drawing, including door and window size and positions, handling of doors 2. Check brickwork quality, line, level, etc. 3. Check in cavities for brick ties 4. Check positions of structural columns 5. Check that tie-downs are present Roof Cover: $350 inc. GST. 1. Check that tie-downs are properly connected to the roof structure 2. Check structure for rafter spacing, underpurlin supports, collar ties, etc. 3. Check that roof cover (tile or tin) is installed correctly, pointing, valleys and flashings are correctly finished, gutters correctly installed, barge boards, fascias, etc are neat and well fixed. Practical Completion / Pre Hand Over: $550 inc. GST. (Two storey properties $600 inc. GST) 1. Check that the building meets the building codes 2. Measurements are taken and compared against the plan 3. Finishes of all doors, windows, walls, plaster and render 4. All cabinetry and tiling checked for sealing, alignment and quality of installation 5. External roof, gutters, down pipes, valleys, flashings, flues, chimneys and ridges 6. Underside of roof, roof space, roof structure, ceiling sheets, insulation type & coverage 7. Check all the floors, Walls and doors are straight and true 8. Basic preliminary plumbing & electrical check. NB: we are not licensed electricians/plumbers. Fee for revisit after all defects / omissions have been attended to by the builder: $300 inc. GST. 1. This visit is optional and usually only required where complications have occurred. All of the above prices include: 1. Driving to and from the site 2. Conducting the inspection 3. Writing of report 4. Discussing all items raised in the report with you. Re: Recomendations for PCI inspectors in WA NOR? 6Jul 07, 2012 1:04 pm I do know of an inspector who works NOR and would probably work SOR. Family friend. He's pretty darn good though. Straight as a die. Qualified builder who also builds homes. ( Bricklaying background originally) We had him do some work on our last house as we were neighbours for over 10 years. He recently did a stint as a government inspector for the Building Commission, was asked if he wanted to continue there when his contract finished but he preferred to go back to being his own boss and, as he said, being stuck in an office for a lot of the day wasn't his thing. http://www.homeinspectionsperth.com.au/ Re: Recomendations for PCI inspectors in WA NOR? 8Jul 09, 2012 3:10 pm dayow Thanks alt0160, will give them a call. And yep, you can see why I want an inspection. Dexter I sent off an email to BSP and gave them house size and details of the build etc and they wouldn't give me a quote until I told them what suburb I live in! Made my alarm bells go off straight away because in my mind, the suburb shouldn't be relevant. Yeah I was unsure why that was as well...! Maybe travelling costs? Anyway I emailed BCI Firth and their prices are approx $2,500 for a double storey for all stages which includes a follow-up... I'm leaning that way. Re: Recomendations for PCI inspectors in WA NOR? 9Aug 04, 2012 5:32 pm CC101 i am going to use perth building inspections. i have used them at roof stage and happy with them. just be aware that perth building inspections is http://www.prespec.com.au/ and http://www.homeinspectionsperth.com.au/ that I mentioned. I saw on another page CC101 you mentioned their 956...... number so I know that's who you meant. BUT there is also perth building inspections http://www.perthbuildinginspection.com.au/ which is a different company and a different person and has a 1800.... number. It seems ridiculous that the business registration board allowed two different companies with almost the same name in WA. I imagine it causes lots of confusion. Re: Recomendations for PCI inspectors in WA NOR? 10Aug 04, 2012 6:59 pm kexkez CC101 i am going to use perth building inspections. i have used them at roof stage and happy with them. just be aware that perth building inspections is http://www.prespec.com.au/ and http://www.homeinspectionsperth.com.au/ that I mentioned. I saw on another page CC101 you mentioned their 956...... number so I know that's who you meant. BUT there is also perth building inspections http://www.perthbuildinginspection.com.au/ which is a different company and a different person and has a 1800.... number. It seems ridiculous that the business registration board allowed two different companies with almost the same name in WA. I imagine it causes lots of confusion. Just looked at my inspection report - mine is perth home building inspections -www.prespec.com.au. sorry if i confused everyone. Re: Recomendations for PCI inspectors in WA NOR? 11Mar 13, 2013 12:30 pm Just for anyone else reading this, http://www.prespec.com.au and http://www.homeinspectionsperth.com.au/ are the same company that obviously has more than one website. They are both the same company mentioned by kexkez. EDIT: Oops, just realised that kexkez had already pointed that out I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16591 That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 82263 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 3237 |
