Browse Forums Building A New House 1 Jul 03, 2012 8:16 am Our appointment is tomorrow and I still have no idea what colour roof and gutters will complment the bricks we want. We are looking at having Austral Blackwood with off white mortar. Any suggestions on what roof and gutter colours we should use? 29/05/12 - Contacts Signed 18/06/12 - Land Settlement 03/07/12 - Building Approval 20/07/12 - Slab Down Re: What colour roof and gutters 2Jul 03, 2012 8:29 am Can you provide more information? Is your roof colorbond or tiles? House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: What colour roof and gutters 3Jul 03, 2012 9:24 am colour bond for the roof 29/05/12 - Contacts Signed 18/06/12 - Land Settlement 03/07/12 - Building Approval 20/07/12 - Slab Down Re: What colour roof and gutters 4Jul 03, 2012 11:03 am You do not mention the colour of the window frames. If you want to use off white flush mortar it narrows your choice of colorbond roof colours. Using off white flush mortar I would recommend: Roof: Deep Ocean, Ironstone or Surfmist. Gutters: same Keep in mind a dark roof increases the temperature significantly in summer however a light coloured roof reflects the heat more but shows the dirt especially after 7 - 10 years when the colorbond paint starts to go “powdery”. If you go for a standard “grey” mortar you could also include the “grey” tones in the colorbond range. Make sure you hold the colorbond sample choice against the selected brick to make sure you’re happy with the end result. All the best……. Re: What colour roof and gutters 5Jul 03, 2012 12:01 pm If you do a google images search you will come up with a lot of pictures of houses. Here is one that I found http://2.bp.blogspot.com/_vztriwGvGPo/TRci3oRZniI/AAAAAAAAAOc/5pFMdO9-dlE/s320/IMG_1488.JPG The front of the house is due to be rendered, but the bricks are Austral blackwood with off white mortar. The roof is tiles, but from what I can see it is quite dark, maybe woodland grey and surmist gutters and fascia. Quote: You do not mention the colour of the window frames. If you want to use off white flush mortar it narrows your choice of colorbond roof colours. I don't necessarily agree with this. Ring Austral and they will give you a list of houses that have used the blackwood bricks. That way you can see what colour schemes you like and what you dont like. Modified Fernside 38 Rawson Homes Blog: http://www.thehousethatmatandjenbuilt.blogspot.com Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=60501 Re: What colour roof and gutters 6Jul 03, 2012 2:01 pm Hi, On my build I am using Boral La Mesa bricks with surfmist for gutters, fascia, roof, garage door and the front door will also be painted this color. The windows are white. Check my thread if you want to see a picture on how it looks. I went for Surfmist to try and ensure the house would be a bit cooler in summer. If you are considering this, please also check your estate convenants to see if you have any restrictions on roof colour. It may also be easier if you keep your posts to the one thread rather than starting a new thread each time. If you edit the first post in your thread you can change the subject of your thread, so if you are asking for more information people will see it. Good luck! House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: What colour roof and gutters 7Jul 03, 2012 2:08 pm One other thing you can try is by visiting the Big M website at http://www.studiom.com.au The envisage software will let you select a house facade and experiment with brick, gutter, roof, fascia, render colours etc. While they don't have the Austral range of bricks (only Boral and Selkirk) hopefully you will be able to find a similar brick in the range they have and then experiment with different colours for the roof and get an idea of how it could look. House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Thank you so much. We ended going with the terrain that’s part of our brick. 2 2540 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28324 Hey. Head to a metal and decide on which profile you will use first. Profiles with larger corrugations can greatly change the appearance of the color in different… 0 3387 |
