Browse Forums Building A New House 1 Jul 02, 2012 10:21 am Having paid the deposits for our block of land and our new home, we are starting to think more seriously about colour schemes, etc. Something that we seem unable agree on is the colour of the Colorbond roof. We both like a combination of grey and pale grey/cream/white render on the walls, but one of us prefers a dark (Ironstone/Monument) roof, and the prefers a light (Surf Mist) roof. Presumably a dark roof is likely to absorb more heat in the summer; how much difference will this really make? Someone suggested that the difference is likely to be minimal - maybe no more than 1 degree or so. Any thoughts, suggestions or opinions would be greatly appreciated. Thanks Re: Dark or pale roof? 2Jul 02, 2012 10:50 am Where do you live? I think in NSW they recommend light rooves, while in Victoria we need to concentrate on heat gain to reduce our energy consumption. I think with good roof insulation it oesn't make that much difference. Re: Dark or pale roof? 3Jul 02, 2012 10:58 am Its actually very surprising and makes a big difference. There have been loads of experiements about this and there are international standards set to measure the temperature difference. I thinks its ASTM E1980 which is about heat refelective stuff but in a nut shell it is certainly more than 1 degree!!! Building the Nautilus with Dale Alcock follow my thread: viewtopic.php?f=31&t=58854&p=909574#p909574 14/8/12 Pre-start! Re: Dark or pale roof? 4Jul 02, 2012 11:57 am kjag Where do you live? I think in NSW they recommend light rooves, while in Victoria we need to concentrate on heat gain to reduce our energy consumption. I think with good roof insulation it oesn't make that much difference. We are in Victoria and in this, our 4th build, have a surfmist (light) roof. In the Summer the sun is higher in the sky and beats down on the roof-so the light roof reflects the heat more. Whereas is Winter when the sun arc is lower in the sky ( less on the roof and more on the walls) we gain the passive solar benefit from the sun heating the house via the windows on the north & east aspects of the house. We have the same level as insulation as our neighbours whose house faces the same way but has a dark colorbond roof-and they can't believe the difference in the comfort factor between the two houses. There are other threads on this Forum which discuss this topic and I suggest the OP has a look at them via the search function. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Dark or pale roof? 5Jul 02, 2012 12:31 pm We've had advice to get a light coloured CB roof so as to reflect the sunlight away - which seems to be what others are saying as well. My Hamptons build (completed): viewtopic.php?f=31&t=63370 Moved in Wednesday 11th Dec 2013 Front landscaping completed June 2016 Re: Dark or pale roof? 7Jul 02, 2012 2:42 pm This table lists the colour bond colour by thermal performance as used in BASIX (NSW). http://www.colorbondcolours.com/commerc ... -and-basix Unless you live in a mountain hut in southern Tasmania, I'd stick to lighter colours personally... Re: Dark or pale roof? 8Jul 02, 2012 5:44 pm Thanks guys. We're in Perth. I'll take alook at some of the other discussions, but it sounds as though a light roof is the way to go. Hi All, I am looking to go with tiles instead of laminate timber flooring throughout my living areas for my new build (Ashbury 29 - Henley). My whole colour scheme is on… 0 24348 sorry mate, not wasting more time on this. Youve completely missed the mark on some fundamentals and regardless of how many times i try and put it to you differently, you… 11 9187 Hi All. I'm currently resurfacing the hardwood floors and when removing the old layers that there's a long dark line running across the boards. Does anyone know what or… 0 12770 |
