Browse Forums Building A New House 1 Jun 22, 2012 8:23 pm Hi guys, Can someone tell me what the price per metre of a solid concrete and steel infill or solid brick and steel infill front fence would be roughly? We have been quoted 55k YES 55k for 46 metres. I mean I'm not fencing from here to china!!! Thanks Re: How munch per metre for brick front fence?? 2Jun 23, 2012 12:43 pm Hi Erin, Depending on requirements there are some alternative products that could give the same look but are much cheaper. We're currently looking at products by both Wallmark and Modular Walls. The panels can be painted or rendered, they come in various heights and you can also have infills. The quotes we've had so far, including install are coming in at around $300 per linear metre (most of it is 2m high) excluding paint / render finish. Not sure if it's what you want but worth a look as it's much cheaper than a full concrete or rendered brick solution. Our Homebuilding Thread 17th Nov - 1st meeting with PJB architect 27th Feb - Signed contract 23rd Mar - Plans approved 3rd Apr - Slab laid 18th Apr - Roof On 10th May - Lock-up 26th June - Handover Old Home Restoration / Renovation Try your local council. They should be able to advise in regards ownership of next door dwellling and give advice as to what steps you have to take before doing any work 1 9796 I recently finished my house and after landscaping, have begun to plan a fence. To be honest its been a bit of an afterthought so I'm after some much needed advice. The… 0 2025 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 |
