Browse Forums Building A New House 1 Jun 20, 2012 12:45 pm Our current (and hopefully final!) home design has a double-garage, with a bit of extra width for storage of bikes &/or the beer fridge etc, and there's a 4m-ish wide single-width garage/workspace behind that which is about 10m (so around 1.5 cars) deep, and then a single-width garage door at the rear leading to the back yard. So that I can have a hoist in there, we've got an interior ceiling height of 3.75m in the garage. I was sort-of considering that, after the house was built, I'd erect a sort-of "mezzanine' level in that rear area for storage. I just deleted a whole bunch of text trying to describe the area I'm talking about ... instead here's a thousand word's worth of picture: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I was thinking maybe allowing about 1.5m height in that storage area, meaning about 2m height underneath it. I was also thinking that if I asked the builder to do it, sure it'd cost more than if I erected it myself; except they support the spanning beams within the walls, and there wouldn't need to be any legs eating into garage-space & getting in the way underneath it. However - are there legality issues? It'll take a while to get an answer from the builders, but someone here might know. Is there any legality problem (NSW / Complying Development) with a storage-area that's only 1.5m high, and is up in the air like that? [it'd have bars or some-such to stop stuff & Forgs from falling] Is there any legality problem (NSW / Complying Development) with that portion of the garage only being 2m high? Something that's only a shelf raised in the air, albeit a large one, doesn't contribute to floorspace calculations if it's not legally tall enough to be a "room" does it? [we're tight on floorspace ratio] Ta in advance! Re: Garage mezzanine/shelf with low height ceiling - legalit 2Jun 20, 2012 5:51 pm You might get it on the same basis as an attic where you can go down to 1.5m as long as 2/3rd of the height is 2.2m. there is some more info here: http://www.anewhouse.com.au/?p=120 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17200 4 6201 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17531 |
