Browse Forums Building A New House 1 Mar 14, 2008 10:10 am hello friends
further to Bobbuilder's suggestion I am creating a new post to update out progress / saga wil our home.. where are right now ? ######################################### Description Actioned Due Completed Lodgement 28/11/2007 29/11/2007 29/11/2007 Application Review Meeting 29/11/2007 03/12/2007 30/11/2007 Application to Assess Officer 30/11/2007 17/02/2008 07/02/2008 Advertisement/Neighbour Notif. 04/12/2007 24/12/2007 25/12/2007 Determination 07/02/2008 15/02/2008 15/02/2008 Status Approval with Deferred Commencement on 15/02/2008 ######################################### Deferred Commencement (1) Pursuant to Section 80(3) of the Environmental Planning and Assessment Act, 1979, this consent will not operate until such time as the following requirements of Council are fulfilled. These requirements are: (i) The 1 x Eucalyptus pilularis (refer to arborists report dated May 2003), 2 x Liquidambers, 1 x Quercus, 1 x Grevillea robusta located at 7A Blanche Street may be removed to accommodate the proposed dwelling. One indigenous tree is to be planted for each tree removed. The replacement trees/tree should have a pot size of 45 litres. The tree species shall be selected from the Indigenous Trees of Kogarah list. They are to be planted using correct and current horticultural practice. These trees shall be stalked using a minimum of two (2) metres x 50mm x 50mm stakes. Hessian tie or similar to secure the trees. (ii) A landscape plan that complies with Condition 1, together with Council’s Landscape and Tree Management Guidelines and Clause 3.13 of the Residential DCP is to be submitted and approved by Council. (ii) Having regard to the difference in the finished floor levels, the internal door opening between the garage and the hall area outside the ground floor bathroom is to be deleted. (iii) Having regard to the extent and position of the proposed excavation, specific details are to be furnished for Council’s consideration to indicate the height, method of construction and location of proposed retaining walls to be constructed around the perimeter of the site. These details should also indicate the intended method of underpinning or supporting existing dividing fences around the perimeter of the site, whose structural integrity may be compromised by the proposed excavation. These requirements are to be satisfied within 6 months from the date of this Determination Notice, failing which, the Consent shall be null and void. This Development Consent does not become operative until the above requirements have been satisfactorily addressed but is legally effective and therefore will expire two (2) years from the date of this notice. Prior to the Issue of a Construction Certificate (2) Payment of the following amounts as detailed below: Damage Deposit of $1820.00 Builders Long Service Levy of $868.00 (3) The development must be implemented in accordance with the approved plans, specifications and details listed below and any supporting information submitted with the Development Application except as amended by any conditions attached to the Development Consent: (i) Architectural Plans (4) Prior to issue of any construction certificate or commencement of any demolition or earth works on site, the applicant shall submit, for acceptance by the Principal Certifying Authority (PCA), with a copy forwarded to Council where Council is not the PCA, a full dilapidation report on the visible and structural condition of the following properties; (i) All neighbouring buildings likely to be affected by the excavation as determined by the consulting engineer. The report must be completed by a suitably qualified consulting structural/ geotechnical engineer as determined necessary by that professional based on the excavations for the proposal, the subsoil conditions and any recommendations of a geotechnical report for the site. The report shall have regard to protecting the applicant from spurious claims for structural damage and shall be verified by all stakeholders as far as practicable.” Reports relating to properties that refuse access to carry out inspections to complete the dilapidation report, after being given reasonable written notice to request access (at least 14 days) at a reasonable time (8.00am-6.00pm), are not to hold up the release of the Construction Certificate. Site Specific Conditions (5) Compliance with all applicable requirements of Council’s Standard Development Conditions. (6) The following lists of inspections are the MANDATORY CRITICAL STAGE INSPECTIONS that MUST be carried out by the Principal Certifying Authority (PCA). (a) at the commencement of building works (b) after excavation for, and prior to the placement of, any footings, and (c) prior to pouring any in-situ reinforced concrete building element, and (d) prior to the covering of the framework for any floor, wall, roof or other building element, and (e) prior to covering waterproofing in any wet areas, and (f) prior to covering any stormwater drainage connections, and (g) after the building work has been completed and prior to any occupation certificate being issued in relation to the building. Certificates from your engineer or subcontractor are NOT acceptable in the first instance for the above inspections. Failure to have your PCA carry out these inspections could result in a delay or refusal to issue an Occupation Certificate. (7) The overall height of the building shall not exceed RL 34.29 above AHD. This is to be verified as achievable by means of a certificate from a Registered Surveyor at ground floor level and at roof frame before the roof covering is installed. #################################### right now i am waiting from 10/2/08 for Clarendon to finish the AHD and Dilipidation report.. I have finished the landscape architects plans and submitted them to council.... #################################### my dealings with Clarendon have been average to say the least... in terms of responses to my questions and variations and of course not the least the prince increase .. Buildling a Clarendon Crestmead in Sydney DA Approved on 20/03/2008 Slab Poured on 02/09/2008 Frame Completed 15/10/2008 Brickwork Complete 2/02/2009 Roofwork Complete 05/03/2009 Re: Building the McMansion ... "Clarendon Crestmead&qu 2Mar 14, 2008 11:49 am ![]() The overall height of the building shall not exceed RL 34.29 above AHD. This is to be verified as achievable by means of a certificate from a Registered Surveyor at ground floor level and at roof frame before the roof covering is installed. Is AHD the same as ground level? I understand there is a regulation that says top of roofline cannot be more than 9m above ground level. But where is ground level ![]() Can anyone explain? Thanks Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: Building the McMansion ... "Clarendon Crestmead&am 3Mar 14, 2008 12:01 pm ![]() AHD is Australian Height Datum.. and is measured relative to sea level. AHD surveys are usually used on flood prone land to ensure the house is above certain flood levels. Your 9m roofline regulation means the base of house (ground level) to tip of roof cannot exceed 9m. OK thanks Mark, but where would the council consider ground level to be? We have a hill on our land rising up from street level about 2.5m high which we are going to excavate and build a basement in, which will then form the foundation for the upper 2 storeys. Would ground level be considered the level at the base of the hill (street level), or the top of the hill? Thanks for any advice. Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: Building the "Clarendon Crestmead" 4Mar 14, 2008 12:09 pm Thanks, I guess we'll find out at building permit stage!
Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: Building the "Clarendon Crestmead" 5Mar 14, 2008 1:53 pm Hello Mark
my CSO at Clarendon is Janet Salama... Buildling a Clarendon Crestmead in Sydney DA Approved on 20/03/2008 Slab Poured on 02/09/2008 Frame Completed 15/10/2008 Brickwork Complete 2/02/2009 Roofwork Complete 05/03/2009 Re: Building the "Clarendon Crestmead" 6Mar 14, 2008 5:20 pm Quote: We have a different CSO to you though. I guess it's just a lucky dip on who you get. Have you been told there will be a different CSO when you are in construction phase? Cl$rend%n change the rule this year. Hopfully, I can get a good CSO in next phase. Re: Building the "Clarendon Crestmead" 7Mar 14, 2008 5:32 pm Yes, I've just found out that you get a new CSO - I think I'd rather have the same contact for the whole time though. It's like starting all over again. Built a Clarendon 'Balmain' 2008 Re: Building the "Clarendon Crestmead" 8Mar 14, 2008 5:59 pm With Blacktown Council - ground level is class as the lowest natural point on your land - regardless of whether the slab/house is above this point.
Therefore, if my land falls 1m left to right (or vice versa) and I build my house in the middle - they measure ground level from 9m from the right hand boundary. After 4 years - we're in! Re: Building the "Clarendon Crestmead" 9Mar 14, 2008 8:15 pm ![]() With Blacktown Council - ground level is class as the lowest natural point on your land - regardless of whether the slab/house is above this point. Therefore, if my land falls 1m left to right (or vice versa) and I build my house in the middle - they measure ground level from 9m from the right hand boundary. Gee I hope they don't do that with us - our land falls 12 metres over 180m and would therefore be impossible to build within the building envelope!!! Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: Building the "Clarendon Crestmead" 10Mar 20, 2008 2:33 pm Hi, what council are you in?
Thanks, Greg (in Ryde council) Re: Building the "Clarendon Crestmead" 11Mar 20, 2008 2:59 pm ![]() Hi, what council are you in? Thanks, Greg (in Ryde council) If that's a question for me Greg, we're under Frankston council, VIC. Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: Building the "Clarendon Crestmead" 12Mar 20, 2008 3:23 pm Ground level for building heights is taken as the natureal ground level (as if no development has occured). That is, ground level is not one number but varies as you move along the block. So, if the maximum building height is 9 m, you can't go more than 9 m above any natural ground level. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Building the "Clarendon Crestmead" 13Mar 20, 2008 4:48 pm ![]() Ground level for building heights is taken as the natureal ground level (as if no development has occured). That is, ground level is not one number but varies as you move along the block. So, if the maximum building height is 9 m, you can't go more than 9 m above any natural ground level. OK, that's great, that's what I thought. The next thing to work out is what constitutes the natural ground level. On our block there is a hill about 2.4m high. Some of it is apparently natural but quite a lot of it was dumped by builders when they developed the estate 7 years ago. As it is 7 years old, and vegetation has grown over it to the point where it is indistinguishable from the surrounding land, would that definitely count as "natural ground level" I wonder? Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: Building the "Clarendon Crestmead" 14Mar 20, 2008 4:53 pm I would double check with your council. Though being on acreage - the rules could be substantially different.
I thought our council was like what Casa2 suggested - however, after talking with the planning department - I found out is was very different where I we are building. (It doesn't really affect us though - 0.5m fall over 15m) After 4 years - we're in! Re: Building the "Clarendon Crestmead" 15Mar 20, 2008 4:59 pm I have posted a picture of the elevations for our block and posted them. In fact did not realise about the nominal elevation when the ADH restrictions are imposed.. We are building at oatley, Sydney. Buildling a Clarendon Crestmead in Sydney DA Approved on 20/03/2008 Slab Poured on 02/09/2008 Frame Completed 15/10/2008 Brickwork Complete 2/02/2009 Roofwork Complete 05/03/2009 Re: Building the "Clarendon Crestmead" 16Mar 20, 2008 5:00 pm Natural ground level is whatever was there before any development. This is not always possible to ascertain, so Council will then take whatever is there now (less any obvious deviations?) Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Building the "Clarendon Crestmead" 17Mar 20, 2008 6:54 pm ![]() Natural ground level is whatever was there before any development. This is not always possible to ascertain, so Council will then take whatever is there now (less any obvious deviations?) Thank you. That is very helpful. Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: Building the "Clarendon Crestmead" 18Mar 21, 2008 11:33 am We have council approval!!! Council officer call us to inform us that the DA has been formally approved yesterday!!!!
Now it is upto Clarendon to get things moving,, will update on the progress as we move ahead. I am getting the trees cut and site cleared by 28/3/2008. Buildling a Clarendon Crestmead in Sydney DA Approved on 20/03/2008 Slab Poured on 02/09/2008 Frame Completed 15/10/2008 Brickwork Complete 2/02/2009 Roofwork Complete 05/03/2009 Re: Building the "Clarendon Crestmead" 20Aug 25, 2008 3:21 pm Hi lobo... how's the project going? C&G -------------------------------- A new building chapter begins.. the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 1828 Thank you ponzutwo and StructuralBIMGuy. Appreciate your response 3 9533 Thanks jas25t! I've heard many good things about the area but have been used to land selling out fairly quickly. I'm hoping it's just the interest rates going up that have… 2 2510 |
