Browse Forums Building A New House Re: SO if you had your choice on ceiling height........... 2Jun 11, 2012 10:06 am It really depends on the style you're looking for. We have gone modern with 2700 ceilings and shadow set. Why do you have to have a lower ceiling for square set? I think it will have something to do width plasterboard sheet widths. They only come in 1200 and 1350. Re: SO if you had your choice on ceiling height........... 4Jun 11, 2012 10:28 am Vess It really depends on the style you're looking for. We have gone modern with 2700 ceilings and shadow set. Why do you have to have a lower ceiling for square set? I think it will have something to do width plasterboard sheet widths. They only come in 1200 and 1350. Haha Vess when did you change your mind on shadow set I wonder if it is a cost factor, can have 2590 with sq set for the same price as 2700 with normal cornice Re: SO if you had your choice on ceiling height........... 5Jun 11, 2012 11:05 am gogo65 Vess It really depends on the style you're looking for. We have gone modern with 2700 ceilings and shadow set. Why do you have to have a lower ceiling for square set? I think it will have something to do width plasterboard sheet widths. They only come in 1200 and 1350. Haha Vess when did you change your mind on shadow set I wonder if it is a cost factor, can have 2590 with sq set for the same price as 2700 with normal cornice YES we can get 2740 with cove cornice for the same cost at 2590 square set....... We just wanted opinions to see what others have done or are going to do! Re: SO if you had your choice on ceiling height........... 6Jun 11, 2012 11:23 am stevcm gogo65 Vess It really depends on the style you're looking for. We have gone modern with 2700 ceilings and shadow set. Why do you have to have a lower ceiling for square set? I think it will have something to do width plasterboard sheet widths. They only come in 1200 and 1350. Haha Vess when did you change your mind on shadow set I wonder if it is a cost factor, can have 2590 with sq set for the same price as 2700 with normal cornice YES we can get 2740 with cove cornice for the same cost at 2590 square set....... We just wanted opinions to see what others have done or are going to do! Hi Stevcm, Which builder allows you to get 2740 with cove cornice for the same cost at 2590 square set? Very curious as we are starting to look at builders and find that to increase to 2740 costs quite alot - unless we are being ripped off. Re: SO if you had your choice on ceiling height........... 7Jun 11, 2012 1:01 pm gogo65 Vess It really depends on the style you're looking for. We have gone modern with 2700 ceilings and shadow set. Why do you have to have a lower ceiling for square set? I think it will have something to do width plasterboard sheet widths. They only come in 1200 and 1350. Haha Vess when did you change your mind on shadow set I didn't. DH talked me into it. Picking my battles. I like yours as well so that helped change my mind Re: SO if you had your choice on ceiling height........... 9Jun 11, 2012 5:43 pm Hi Stevcm, Which builder allows you to get 2740 with cove cornice for the same cost at 2590 square set? Very curious as we are starting to look at builders and find that to increase to 2740 costs quite alot - unless we are being ripped off.[/quote] Hi, Sorry i'm wrong DH tells me it is about $2000 diff for the downstairs......47sq carlisle home......I misread the quote.... Thanks. Re: SO if you had your choice on ceiling height........... 10Jun 11, 2012 5:51 pm So what s most expensive? I assume the 2700mm with cove cornice is more expensive? Personally I think 2700 is best particularly for ground floor. Lucky for us our builder has 2700mm as standard and we paid $4000 for shadowline cornice throughout( our builder won't do sq set as they say they are more prone to cracking,) in saying that sq set is normally at least 50% cheaper than shadowline and many project builders don't even offer it as an option. I would go 2700 with normal cornice over 2590 with sq set, 2590 looks like normal height to me. Re: SO if you had your choice on ceiling height........... 11Jun 11, 2012 6:40 pm gogo65 I would go 2700 with normal cornice over 2590 with sq set, 2590 looks like normal height to me. I agree! Ground floor should be standard 9ft. The reason why 2740 is with cornice is because they can leave a smal gap for skirting and the gap at the top for the cornice to cover. If you have 2740 as square or shadow set it's 2 x 1350 boards plus an extra piece of off cut to make up the distance. Re: SO if you had your choice on ceiling height........... 12Jun 24, 2012 12:10 pm gogo65 So what s most expensive? I assume the 2700mm with cove cornice is more expensive? Personally I think 2700 is best particularly for ground floor. Lucky for us our builder has 2700mm as standard and we paid $4000 for shadowline cornice throughout( our builder won't do sq set as they say they are more prone to cracking,) in saying that sq set is normally at least 50% cheaper than shadowline and many project builders don't even offer it as an option. I would go 2700 with normal cornice over 2590 with sq set, 2590 looks like normal height to me. Hi Gogo65, Who are you building with, as I presume your builder includes 2700mm as standard ceiling height? Re: SO if you had your choice on ceiling height........... 14Jun 24, 2012 5:50 pm I personally don't like square set cornice - so I would go the 2740mm with cornice I wish we increased our ceiling height when we built - oh well... may need to build again!!! (ssshh don't tell DH!) Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: SO if you had your choice on ceiling height........... 15Jun 29, 2012 3:50 pm Hi all We are going 2730 ceiling on our mid level. For an area of 94m2 it cost $4720. It was an additional $16 a lineal meter to square set it. This area includes both bedroom doors and an alfresco stacker. Did everybody go taller doors both internal and external where they had the higher ceilings ?? Cheers Hack Re: SO if you had your choice on ceiling height........... 16Jun 29, 2012 8:38 pm Hi,we are having 32 coarse bricks through kitchen,living,dining,entry & elfresco. After going into a display home with this height we were sold,cost $4,000 through Ventura. Money very well spent,makes such a huge difference to the feel of the rooms. kat Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81883 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39692 |
