Browse Forums Building A New House 1 Jun 06, 2012 8:00 pm Hi guys, Long time reader, first time poster seeking some help. Got our tender recently and our additional site cost (in addition to standard package) was over $85,000. Break down costs - H1 Slab $7550 Removal Soil - $9,500 Elecitical connections for 3 phase acorrs the stree - $4,000 Sewer - $4,000 PA Stormwater - $10,000 PA Rock Excavation - $5,000 PA Traffic Control - $10,000 PA Meterial Handling - $5,000 Tiger Tails - $2,000 Footpath Protection - $1,500 Hydraulic Plans - $850 AHD - $570 Stepdowns x 2 in house - $26,500 My understanding was start of the house to end has 2m difference in height which require cut and fill. Also, LHS back 1m cut, LHS front 0.6m cut, RHS back 0.4m cut and RHS front 0.4m fill. Been doing some research and this site cost seems to be a bit ridiculous. Any suggestions would be appreciated. Re: Site Cost blow out 2Jun 06, 2012 8:31 pm That is totally ridiculous! How big are the step downs? By the sounds of your cut and fill it shouldn't be that bad. My whole slab cost about the same amount as your two step downs. Geezus! Soil removal - how much is there to remove? That is excessive. I had similar cut n fill and spent $3750 on soil removal which was 15 loads and we dug out an 10,000 litre underground tank. Traffic control? Do you live on a highway or major road? We haven't needed any traffic control. Material handling - what does this relate to? Re: Site Cost blow out 3Jun 06, 2012 9:23 pm We shifted 1400 M3 of dirt (in not out, and at 140 loads) and the slab, all in total cost approx $34K. Traffic control??????? Is the porta loo that busy?? Seriously think you are being ripped off. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Site Cost blow out 4Jun 06, 2012 10:02 pm I'd love to know where you are building and who your builder is! Those site costs are half of the base price of our whole HOUSE!! Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Site Cost blow out 5Jun 06, 2012 10:40 pm I'd be getting another tender or two from other builders to compare. Unless you really LOVE the home your builder quoted for, but with site costs quoted so high I think I would quickly unlove it. We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Site Cost blow out 6Jun 07, 2012 12:46 am This is really a rip off. But them how big is your land and where about? If it is a normal sized block in a suburb and not on a main street etc, I would seriously consider looking for other builder unless you really love the home they design or build. Remember, this is your first blow out at starting point. You can really predict that it can only be worse at later stage. Re: Site Cost blow out 7Jun 07, 2012 8:22 am One question nobody has asked, how big is your house? Until you answer that question we can't answer your question properly. If it is an average size than yes those costs are 3-4 times the average. Good luck. Re: Site Cost blow out 8Jun 07, 2012 6:47 pm The stepdowns are 2 steps each - 0.5m ish?
Traffic control because next door has a bus stop in front of their house. I don't live on a highway, just a normal street and the bus comes every 15m peak and 30mins off peak. Meterial handle - I've been told because there will be a slope at the front of the house and no access to the back, once the frame is up, all the material (bricks) needs to be positioned up right. . Basically, the house will have 3 cut - garage and front living room 3.7m height, middle - 3.2m height and back 2.7m height. They said the land has 3m slope in total, which they set back 10m picked out an area has 2m slope. If I stand in front of the house, I can't see its 3m higher than me. It's probably not a good idea to disclose the builder at this stage. Thank you all for you response. Re: Site Cost blow out 9Jun 07, 2012 7:57 pm tuspecial Hi guys, Long time reader, first time poster seeking some help. Got our tender recently and our additional site cost (in addition to standard package) was over $85,000. Break down costs - H1 Slab $7550. I dunno what all these classes are in the east, but slabs vary greatly and this house is large than the norm nd has to be stronger as is two story Removal Soil - $9,500 That's a lot f soil, but it sounds like a lot of a slope in block Elecitical connections for 3 phase acorrs the stree - $4,000 Three phase cost more o tap into and other side of street may mean thy have to go under street to get it Sewer - $4,000 PA If you are not on it, this is cheap o connect compared to Perth Stormwater - $10,000 PA Gonna need a lot of this with that slope , and some prior to build I suspect or it will all wash away while building Rock Excavation - $5,000 PA Rocks need to be broken up before digging out, this can vary and it may alter the machinery required Traffic Control - $10,000 PA Bus stop says it all. Meterial Handling - $5,000 This may not be needed but then your traffic control would go up each time you have a delivery Tiger Tails - $2,000 No idea what this is Footpath Protection - $1,500 Councils require a bond for footpath integrity that you usually get back, but tht bus stop they take no chances and builder must protect Hydraulic Plans - $850 Dunno AHD - $570 Ditto Stepdowns x 2 in house - $26,500 Cost a lot as they have to be built up to stop thm crumbling with the weight fva second story. My understanding was start of the house to end has 2m difference in height which require cut and fill. Also, LHS back 1m cut, LHS front 0.6m cut, RHS back 0.4m cut and RHS front 0.4m fill. Been doing some research and this site cost seems to be a bit ridiculous. Is also parramatta , is this an upper location, may explain an inflated cost I have only driven thru it, I remember it as very hilly and very green. Any suggestions would be appreciated. Good luck Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: Site Cost blow out 10Jun 07, 2012 10:41 pm Yep, unreasonable, they are taking you for a ride. We have a P class slab, a 600mm step through the house and a 450mm step into garage. Needed 32mpa concrete. 470sqm house, only extra cost was extra piering. Although our builder didn't break down costs, there is no way it was even 20% of that. Start looking for another builder. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37140 Thanks for the insight! My plot is a new development so hopefully I won't have too much problem during build as everyone should be roughly building together. I also… 2 3372 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7119 |
