Browse Forums Building A New House Re: Soundproofing Costs 2May 29, 2012 11:53 am You need two main things, more mass like thicker plaster or acoustic batts and more sealing around doors windows and pipe penetrations. It can cost a heap, but it depends on if you just want some more peace and quiet or if you leave adjacent to tram depot! @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Soundproofing Costs 4May 29, 2012 4:21 pm You could just use sound screen insulation and that will certainly make a difference. CSR bradfords do it supply and install. Re: Soundproofing Costs 5May 29, 2012 9:09 pm There's soundproofing and then there's soundproofing. For example, stuff that might be sufficient for your home cinema certainly wouldn't have been sufficient when we were in a recording studio, with broadcast radio being a step below that, and then our requirements for say sports commentary another step below that. The former is a case if "if you have to ask, you can't afford it". Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. Re: Soundproofing Costs 6May 31, 2012 11:27 am Upgrading to 13mm plaster on certain walls and ceilings is an inexpensive sound upgrade. As are noise isolating batts in lieu of thermal batts. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Soundproofing Costs 7May 31, 2012 11:35 am Our media room is in the back corner of the house so we did sound deadening on the 2 internal walls only. The walls arent very big but it only cost $250 to purchase the batts and the builder put them in for us before the plaster went up You need to be a bit more specific i think as to what you want done because if you only want one room it would probably be affordable, if you want the house done it would probably cost a couple of thousand dollars Re: Soundproofing Costs 8May 31, 2012 12:36 pm We had soundproof R2.0 batts installed in the walls surrounding the master bedroom, ensutie and powder on the ground floor and 2 bedrooms, study, bathroom, toilet on the top floor. This came to about $1500. We also had it put between the ground and 1st floor for the whole floor (got a 2 story) which came to $900 ish. All in all it was about $2400 to get it in the places we want to keep a little more quite. We just wanted it to stop that hollow echo of new house can sometimes have in certain places. I guess it depends on what level you want to go to with soundproofing. I think ours is pretty much minimum but still provides some level of privacy (or loud music, stomping from kids). Plus.. i hate going to a new homes toilet area and hearing echo... if you know what I mean... Thats one place I want a little privacy!! ... in case we have visitors... Re: Soundproofing Costs 9May 31, 2012 11:53 pm You can get soundstop plasterboard it does cost a bit, I had one room done and it was more expensive for the plasterboard upgrade than the acoustic batts...its recommended to do both if possible. I had this done for 1 wall only If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26168 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11658 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9146 |
