Browse Forums Building A New House Re: When do they Install External Powerpoints? 2May 28, 2012 12:35 pm Can you see wiring in the required position that has been pulled through the gyprock/brick? If not - then it has probably been missed. The power point facings won't be installed until after inside painting has been completed. Re: When do they Install External Powerpoints? 3May 28, 2012 1:34 pm If it's just a single skin brick wall in the garage they will run the wire inside a condute down the bricks. As au said if theres no wire coming out through the brickwork they've probably missed it or bricked over it because the wire may have been behind the paper. If it's a lowset house its not that hard to get a wire down the cavity either way. Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13781 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8651 |
