Browse Forums Building A New House Re: Vess's Build 161Jul 07, 2012 12:38 am Vess, what a great progress you have there! Can I ask about the insulation going in the ground floor ceiling? Is that a standard all builders must do or you add it yourself? Can it reduce the sound of people walking above/ reduce the water sound in pipe? I don't see much downlights cabling on the ceiling btw.... Btw I love your lounges material.... Do you mind to pm me about the downlights place ? We're looking to buy too but only 63 lights... Thanks, Vess. Re: Vess's Build 162Jul 07, 2012 7:04 am willcres Vess, what a great progress you have there! Can I ask about the insulation going in the ground floor ceiling? Is that a standard all builders must do or you add it yourself? Can it reduce the sound of people walking above/ reduce the water sound in pipe? I don't see much downlights cabling on the ceiling btw.... Btw I love your lounges material.... Do you mind to pm me about the downlights place ? We're looking to buy too but only 63 lights... Thanks, Vess. The insulation you see in the underfloor is R4.1 ceiling batts because I have the hebel floors an they provide acoustic properties. I was told I didn't really need to add anything but I wanted to make sure I couldn't here thumping noise from footsteps ever again in my house. It is such a pet peev of mine. It's not standard practice to insulate the mid floor/ceiling of double storey home but you definitely can and I absolutely would if I had the plywood floors upstairs. There's a couple of products you can use that would work. Sound screen optimo made out of rockwool or there is another underfloor product made from glasswool which is dense an rigid so it may only be 90mm thick but it is dense unlike the fluffy ceiling batts you see at my place. That why you can't see the wiring for the downlights. We got Brightgreen downlights and they retail for around $100 each. 5yr warranty. LED fully dim able and they are 903 lumens bright which I have been told is the brightest LED on the market. They look lovely in the box. I can't wait to have them installed. Re: Vess's Build 163Jul 07, 2012 7:45 am Thanks for the info, Vess. So how to make it stick to the ceiling floor? Will it obstruct the electrical cabling in the future? With downlights, wow! Would love to see it oneday... But My budget is not even close to $100ea...he..he.... Re: Vess's Build 164Jul 07, 2012 8:51 am willcres - we also did floor sound insulation. It is not standard, so you have to pay for it yourself on top. Standard is usually just external walls and roof ceiling. From what I can tell, Wisdom only provide the bare minimum inclusions, so I would expect Wisdom would not have extra insulation included. We also upgraded and got all our internal walls insulated as well. That will be an owners cost, not the builder. SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Vess's Build 165Jul 07, 2012 9:11 pm willcres Thanks for the info, Vess. So how to make it stick to the ceiling floor? Will it obstruct the electrical cabling in the future? With downlights, wow! Would love to see it oneday... But My budget is not even close to $100ea...he..he.... To hold the insulation in place they use a fine strapping material and staple it to the underside of the joist. Acoustically speaking you don't 'stick' it to the underside of the upstairs floor. The gap between the flooring upstairs and the insulation batt assists with the acoustic result. The insulation needs to have clearance spaces cut out for the downlights but if you are having pendants its not an issue. They run the electrial wiring first then insulation goes in so the clearances are correct. You can definitely get cheaper good LEDs. Go to the lighting store where world of tiles is in Victoria road c/hill. Re: Vess's Build 166Jul 07, 2012 9:21 pm Todays progress was a-plenty...... Undercoat on walls and ceilings upstairs and half of downstairs. Not much to go for undercoat. We did a test patch of the Lexicon for the ceiling and it was way too grey/white against the downlights we picked so off I went to Bunnings to do colour matching to our downlights. Result: Big White double strength. First coat of big white on ceilings upstairs done. Sample colours for bedrooms tested. Photos tomorrow. Another day up and down a scarey ladder. Hired an industrial vacuum to suck up all the plasterers dust and the screeding crud. Nice n tidy n clean now. Ready for wall painting. Re: Vess's Build 167Jul 07, 2012 10:35 pm Vess, we have big white on our trims, but double?. How on earth do you double strength a white paint Might come for a visit tomorrow, loooked like everyone had painters today, ours came and painted the alfresco ceiling and looked liked back neighbor also had painters. Re: Vess's Build 168Jul 07, 2012 10:40 pm Vess To hold the insulation in place they use a fine strapping material and staple it to the underside of the joist. Acoustically speaking you don't 'stick' it to the underside of the upstairs floor. The gap between the flooring upstairs and the insulation batt assists with the acoustic result. The insulation needs to have clearance spaces cut out for the downlights but if you are having pendants its not an issue. They run the electrial wiring first then insulation goes in so the clearances are correct. You can definitely get cheaper good LEDs. Go to the lighting store where world of tiles is in Victoria road c/hill. Thanks for the info, Vess. Good progress you have there! Re: Vess's Build 169Jul 08, 2012 7:04 am gogo65 Vess, we have big white on our trims, but double?. How on earth do you double strength a white paint Might come for a visit tomorrow, loooked like everyone had painters today, ours came and painted the alfresco ceiling and looked liked back neighbor also had painters. Double strength is double the tint to make that particular white. Not sure what we will do on skirts and arch's yet but I want to colour match the white to the shutters. DH is NOT going to like having 2 different whites ie ceiling and woodwork. He'll see why when the time comes. I still think the only thing that will hold us up from moving in is the gas connection. The day I get that I will give notice on rental provided kitchen is in and bathrooms are done. Re: Vess's Build 170Jul 09, 2012 6:20 pm Lots happening onsite. I have Monday & Tuesday off this week to direct traffic and paint whatever I can. First coat on daughters room - purple crazy. This one taken around lunchtime. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This one taken later in the arvo. She has white furntiure and we will have white shutters and white skirting and architraves. I'm getting some wall stickers with owls to decorate. Can't wait to finish it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Half a staircase Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tilers were grouting downstairs, putting additional waterproofing on top of the screeding in bathrooms and screeding the alfresco area ready for tiling tomorrow. Stairs finished being installed tomorrow and garage doors scheduled to be installed as well. Looking at a feature wall in our bedroom. We have a dark grey leather bedhead and are getting bedside tables made in semi gloss poly in Guilded Grey. This colour is half strength Guilded Grey and then we will do a much lighter grey for the rest of the room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Vess's Build 171Jul 09, 2012 6:43 pm Wow Vess! Great to see some colours for a change (and yep I am just as guilty for painting the same colour throughout). I'm planning on getting owl stickers for my youngest's room. Have you found some good ones yet? Re: Vess's Build 172Jul 09, 2012 7:01 pm The purple looks good Vess, DD had a purple room like that when she was about 6. look forward to seeing the stairs completed. Like the grey , DD has just decided on a dark grey feature wall, should be nice with her white leather bed and furniture Re: Vess's Build 173Jul 09, 2012 7:04 pm greenfish Wow Vess! Great to see some colours for a change (and yep I am just as guilty for painting the same colour throughout). I'm planning on getting owl stickers for my youngest's room. Have you found some good ones yet? Yes. I have a friend who has a small business on faceb00k called Cherry Blossom Decor. She does some amazing stuff. I've been waiting waiting to buy her stuff to get daughters room beautiful. I also made an owl patch work quilt September last year. I'll try and find a pic of it. It was my first attempt and I totally enjoyed it and it turned out really nice. Re: Vess's Build 174Jul 09, 2012 7:06 pm gogo65 The purple looks good Vess, DD had a purple room like that when she was about 6. look forward to seeing the stairs completed. Like the grey , DD has just decided on a dark grey feature wall, should be nice with her white leather bed and furniture DD is 6 next month so perfect timing huh Re: Vess's Build 175Jul 09, 2012 11:21 pm Nice colors, Vess! Love the grey (my fave ) & the bottom stairs.... Re: Vess's Build 176Jul 10, 2012 4:19 am Here is the patchwork quilt I made whilst recovering from thyroid and gall bladder surgery (had them out at same time). The quilt took a week. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's 4am and I can't sleep!!! There is so much going on it's hard for the brain to stop spinning. It's going to be a long day I have a blue and grey room to do today then do a site clean up (again!! ) Re: Vess's Build 177Jul 10, 2012 9:50 am Oh poo on the lack of sleep Vess I hate that. Quilt looks great! Well done. My eldest DD turns 6 not long after we move in - although she is getting butterflies not owls Re: Vess's Build 178Jul 10, 2012 10:49 am Ooohhhh nice ... my fave colour is purple For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Vess's Build 179Jul 10, 2012 3:19 pm Another productive day..... massive body aches all over. Going back to work tomorrow for a rest before I do it all again on the weekend. This is the youngest boys room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Alfresco tiled - yay Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Garage doors didn't arrive today. Apparently I've got my days mixed up. They're booked in for tomorrow. All my internal doors and the front door arrive Friday and they will start being installed that same day. Skirts and archs arrive roughly next Thursday. Still no firm date for the kitchen to get installed but he did say he would start installing from next week so who knows what it will be he is installing. Hope it's kitchen, laundry, pantry and bring the vanities too thanks Once this gas is connected, I think I will be comfortable giving notice. Still on target for 4 August move in - so far. That will make it a 6mth build with roughly 7-8wks lost from 'issues' and not counting the rain at the start of the year. Not bad huh Re: Vess's Build 180Jul 10, 2012 3:21 pm Woo hoo For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! regardless, your contract stipulates a payments schedule and SOPA doesn't give provision to that scenario. Your contractual terms appear to stand. Hence get a lawyer, it… 4 11986 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13893 I ended up going with 'Andrew Belic Construction Co.' https://www.instagram.com/andrewbelicconstruction/ 2 59877 |
