Browse Forums Building A New House Re: Ray's Adelaide build 43May 16, 2012 2:16 pm My building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=56583&start=120 Re: Ray's Adelaide build 44May 16, 2012 2:17 pm For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Ray's Adelaide build 46May 16, 2012 2:23 pm My building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=56583&start=120 Re: Ray's Adelaide build 48May 16, 2012 3:38 pm Can you get some proper info on that courtyard - it means an extra wall which costs - and I don't think you will get much benefit at all - except as a decorative feature. Could end up being a trap for dead foliage that someone will have to sweep up. Probably by 11 or noon the sunlight will be gone over the roofline. Use the space internally or make it wider and glass it in and even then, it won't be sunny for that long (IMHO). Re: Ray's Adelaide build 49May 16, 2012 3:45 pm If the roof is flat over study, it will be fine... Depends on this amazing facade he keeps teasing us with....and the roof lines... If it has any sort of pitch, I think it will bring shadow to courtyard, but might not bring shadow to dining?? Mmm, what can a dark shady area be used for? A fernery... Re: Ray's Adelaide build 50May 16, 2012 3:53 pm Sorry Kiwi- I meant to add " ala Kiwi" to that part as well.... Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Ray's Adelaide build 51May 16, 2012 3:56 pm yes, a VERY big blooper there. trying to take the lime light. i dont know..what is this forum coming to. it is crumbling!! Re: Ray's Adelaide build 52May 16, 2012 3:59 pm I'd be perfectly happy without the courtyard personally, but we need to increase the ratio of northern windows. That's really the only reason it's there. Might have to see what we can do with a skillion roof and some clerestory windows. If I can find a way to make that work with a facade the boss will be happy with, that'd be an ideal solution... My building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=56583&start=120 Re: Ray's Adelaide build 53May 16, 2012 4:12 pm remember, it will only be shady in the middle of winter, in summer the sun will be right over the top, making it a very hot fernery and will kill em all. each side of the longest day, you will have a little shade, and then a bit more etc.. I actually really like it and think it will give light to the dining area and will be a nice feature. esp if water is put there too... but do what works for you. Re: Ray's Adelaide build 54May 16, 2012 5:03 pm Deemaree * Add hall space to Bed2 and move robe- Bed 2 will need soundproofing anyway being next to Theatre-so that also takes care of "noise factor" from Master! ) "noise factor" from master lololol!! Love this!! And what ah.....noise factor would you be referring to =P Re: Ray's Adelaide build 56May 16, 2012 5:59 pm CluelessOne What are people's views on the courtyard. I think a smaller one will be fine as it probably won't be used as a functional area, but what is wide enough to get amount amount of light in? And yes kiwi, that makes perfect good sense! Back to your original plan, and in response to query above, I would definitely shrink or move the study completely to give a bigger courtyard there for sure. Not just more light, but also space to put a feature / greenery to look onto rather than study wall which would not be ideal. Then you wouldn't need clerestories (as you said roofline problem) because a bigger courtyard will give you more light. Otherwise you will still have a lot of shadow from the study. Given the difficult block, you may as well try to prioritise at least that living area to get good light. Second idea is to drop that double hallway. If you play around with that space, can you move the study somewhere else entirely then? SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Ray's Adelaide build 57May 16, 2012 6:05 pm CluelessOne I'd be perfectly happy without the courtyard personally, but we need to increase the ratio of northern windows. That's really the only reason it's there. Might have to see what we can do with a skillion roof and some clerestory windows. If I can find a way to make that work with a facade the boss will be happy with, that'd be an ideal solution... You would be mad to lose the courtyard as you will definitely be in shade and cold. Do you have Google Sketch Up? It is free and a great program to do 3D drawings of houses where you then switch on the sunlight (and you can choose at different times of the day and seasons). It really shows how much light you get and when. SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Ray's Adelaide build 58May 16, 2012 6:09 pm I had thought about moving the study up to where the laundry is now, and having the two kids rooms and bathroom up there too. Then moving the laundry and master bed (apparently now known st the thumpy squeally room ) down to the western side. I think I need to play with the dimensions again to see what will fit. Re: Ray's Adelaide build 59May 16, 2012 6:11 pm Oh cool, thanks T. I just downloaded it but haven't had much of a play with it yet. I know what I'll be doing tonight after the kids are down! My building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=56583&start=120 Re: Ray's Adelaide build 60May 16, 2012 6:16 pm CluelessOne Oh cool, thanks T. I just downloaded it but haven't had much of a play with it yet. I know what I'll be doing tonight after the kids are down! yeah, my DH swears by it. You can turn the house around, walk around and over to get all dimensions. And excellent for seeing where the shade falls. That should give you the best indication of how much space you need there. My avatar was drawn up with Google Sketch Up. Good luck! SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and… 0 3246 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17516 thank you! do we need to get this or our builder before we commence new build on the block? 2 10404 |
