Browse Forums Building A New House 1 May 12, 2012 10:20 pm Hi, I am building a house at Point Cook, and my parents did the color selection, at that time, none of us knew there is such a thing: FC infills. We all thought the thing above windows would be bricks. Now after the lock-up stage, I found the boards above side windows are FC infills, and we originally selected the color: Colorbond Headland for it, I myself thought my parents chose that color by mistake as they did not know the fact, and I did a search in this forum and saw someone suggested the same color as the gutter, so I changed it with the builder to the same color as the gutter which is Colorbond Ironstone, and the builder said this kind of change usually cost $750, but did me an exception for no charge. When I told my parents about this change, they still prefer the previous color, now I wrote a letter to my builder, asking if it is possible to change it back for free, if that is not possible, we need to go with Ironstone, but I wonder if it is possible to repaint it to other colors later? Here is the photo(unpainted): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We used to choose Headland which is the same color as the down-pipe, now it is changed to the same color as the gutter(Ironstone). Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10224 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10925 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20604 |
