Browse Forums Building A New House 1 May 10, 2012 1:16 pm Hi, I am building a new home, now work finished brick work .mostly next week lock up. My concern is, builder made front elevation not as per drawing .In the front elevation drawing there is timber cladding above the windows until ceiling in the front outside wall. now finished the brick work on front wall there is only a brick gap between window and wall (as per drawing 300mm gap ) so there no place to put timber cladding.What i can do at this stage? please advise me .can i asking a compensation ? or asking to change the height of the wall (too difficult). If builder not agree with anything, can i going for a dispute? what is the procedure?. Thanks, Tom Re: Built not as per drawing 4May 10, 2012 2:38 pm Speak to your supervisor immediately. If the as constructed doesnt match the plan, then absolutely they MUST fix it. I would refuse to authorise progress payments until it is fixed as it is part of the base structure. If you want to go the compensation route, you can negotiate, but you paid for the elevation you wanted, you should get it *edit: that being said, the drawing provided doesn't look like it has a 300mm gap. To me it looks like a 1 brick gap (86mm) and the brickwork extends down below the pier. A photo to compare against the drawing would be ideal 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4233 Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful 3 2673 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12883 |
