Browse Forums Building A New House 1 May 07, 2012 10:43 pm Re: Lockup Stage finished, paper instead of brick above wind 3May 07, 2012 11:25 pm deb17 should b brick if thats what the contract says! brick infills r more expensive and I would b making sure thays what u get. Thanks for your reply, is it possible that that is just something temporary for the lock up stage? Re: Lockup Stage finished, paper instead of brick above wind 5May 07, 2012 11:31 pm deb17 ours were not like that. They were bricked at lock up stage. Is it like plaster? because the cheaper infills r like a plaster, to look at or timber. I don't know what it is, but when I touch its edge, I can certainly pill it. Re: Lockup Stage finished, paper instead of brick above wind 8May 08, 2012 10:48 am They need to get steel lintels above each window to do the bricking. If your contract says Brick Infill, do not pay for lockup until they put the bricks - Might have been missed Orchid 4200 with Burbank: Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=53034 House Built in 7 Months and 2 weeks Re: Lockup Stage finished, paper instead of brick above wind 10May 08, 2012 4:54 pm Should be like over your door, the brick courses just extend across a steel lintel. Not going to be much fun for the brick to fix if the builder has done this on purpose 2 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6275 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10892 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20559 |
