Browse Forums Building A New House 1 May 03, 2012 3:27 pm Hello all, I am starting to build a new house and have been told by my builder that i will need retaining walls on the sides. Unfortunately my covenant does not allow Timber Retaining walls. So I am wondering what is the next cheapest option. Both walls are gonna be 500mm high and about 10m long. Any help will be greatly appreciated. Regards, Re: Retaining Walls 2May 03, 2012 4:29 pm Hey there, there are heaps of threads on retaining walls in various sections. I built mine with sandstone roughs, 25tonne of rock cost $1300 cash and had access to a bobcat for free to build the wall. Depending on what look you're after, and what resources you have available to you will depend on what sort of wall you end up with. You could probably get away with a wall, say 2 retaining blocks high, 400mm and then batter the ground level up to the 500mm mark and plant it out. Re: Retaining Walls 3May 03, 2012 5:01 pm Check out boral online and see if you can find a factory outlet close to you, I am sure you could find retaining wall blocks cheap. We did this and also our pool pavers and all up saved over $3000 on full retail! Just remember also depending on state regulations a retainer must be at least 1 metre off the boundary and under 1000mm in height to not require a permit Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6062 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11116 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11764 |
