Browse Forums Building A New House Re: Bushfire 12.5bal cost 21May 11, 2012 12:51 pm Our bushfire is BAL12.5 (the lowest bushfire rating) and we had to have the following Flyscreens with corrosion resistant mesh including opening doors Merbau for exposed timber beams (wood has to be fire resistant) Garage door seal Spark arrestors to external brickwork Merbau external door jambs 4mm toughened glass in french doors and bottom panels of 2100mm windows. For us it was $5,600. Ours is a large house though, so might be cheaper on a smaller house. Modified Fernside 38 Rawson Homes Blog: http://www.thehousethatmatandjenbuilt.blogspot.com Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=60501 Re: Bushfire 12.5bal cost 22Aug 31, 2012 6:38 am the design side is important as if one has aluminium screens one doesnt need the special glass not with 12.5. also only needed if glass is less than 400 mm above ground or decks. so one could have windows sitting up off the floor and be ok. leighton at clark new homes Re: Bushfire 12.5bal cost 23Aug 31, 2012 10:16 am In the contract they allowed just under $6500 which we ended up not having to pay as not in a bushfire zone! But I guess it depends on area, house, not sure how it all works. Re: Bushfire 12.5bal cost 24Sep 30, 2012 9:13 pm part of the issue is design. a lot depends on how the house is designed and built. naturally builders will handle the process differently but it is complex and most dont know because they dont read the australian standard. leighton at clark new homes Re: Bushfire 12.5bal cost 25Sep 30, 2012 9:30 pm leighton part of the issue is design. a lot depends on how the house is designed and built. naturally builders will handle the process differently but it is complex and most dont know because they dont read the australian standard. leighton at clark new homes Is your criticism of other builders here and in your other posts meant to attract business? Because it certainly wouldn't work for me - just makes you look bad. As to the topic - we are BAL 12.5 but we don't have to screen our entry doors - I wonder why this is different? Building the Ascot 35 with Carlisle Homes in Pasadena Estate, Clyde VIC My build thread: viewtopic.php?f=31&t=59776 Re: Bushfire 12.5bal cost 26Oct 01, 2012 11:00 am we are building in BAL 40/FZ and in Leighton's defense it is very upsetting how little builders now about the australian standards. But i guess as more houses are built with this they will learn. I just know in my job when knew research or information comes out, I make an effort to learn it! Re: Bushfire 12.5bal cost 27Oct 04, 2012 4:43 am that is right, my point is that this is all quite confused. the reason is not that builders dont know the standards, this comment applies to surveyors inspectors and consumers. but i am also saying that design is quite important. the materials that you use and the design system make big differences and make it hard to compare apples for apples leighton clark new homes. i identify myself so no-one can say that i dont. Re: Bushfire 12.5bal cost 28Oct 04, 2012 8:44 am Agree also with your point leighton about surveyors/inspectors. As a consumer I expect these people to know to help but they just don't...yet, hopefully! 7 12018 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37150 Fair Trading can issue orders to rectify and complete but once the matter goes to NCAT these orders are automatically vacated. You will have to terminate contract and sue… 21 29751 |
