Browse Forums Building A New House 1 Apr 30, 2012 4:06 pm Hey All; we are building in a stockland estate which requires colorbond fencing. Just wondering if anyone knows roughly how much I Should be paying for this including installation? Our block is 12.5 X 36m - so need appx 80m of fence, 1.8m high and will need a gate also! Hope anyone can help?? Thanks Kerry Process: Land Settlement: 17/02 House colours picked: 20/02 Slab: 25/03 Framework: 28/03 Windows & Roof framing: 01/04 Plumbing: 06/04 Lock Up Stage: 22/04 Paint & Tiles: 14/05 Re: Colorbond Fencing- cost???? 3Apr 30, 2012 4:35 pm I had quotes between $4500 and $5000 installed for 42m. I ended up just buying the materials and installed it myself for $1700 23 Aug 2011: Land settlement 14 Sep 2011: Block levelled 20 Oct 2011: Slab 3 Nov 2011: Frame 10 Feb 2012: Handover http://s1098.photobucket.com/albums/g372/Dazzab6/ Re: Colorbond Fencing- cost???? 4Apr 30, 2012 4:48 pm $75-85 per meter installed, plus removal of any existing fence and hope it is not Asbestos ( $25 per sheet to remove if you dig it up first yourself ) Perth Pricing Tho Luck Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: Colorbond Fencing- cost???? 6Apr 30, 2012 9:13 pm Yep, I was told not to pay more than $65/m. I'll probably have the same requirements as you (diff colour) as I'm in Stockland's Highlands estate. Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. Re: Colorbond Fencing- cost???? 7Jun 20, 2012 4:44 pm I just got quoted $103p/m for the supply and install of 1800mm colorbond, raked with TP sleepers underneath... this is in Canberra, so I guess prices would be a bit higher, but $103p/m seems a bit steep, doesn't it? Re: Colorbond Fencing- cost???? 8Jun 21, 2012 8:52 pm $65 p/m in Melbourne ... South Eastern Suburbs.
Fence goes up next week. EDIT: It took 4 quotes to get the price this low, 18.5m 1800mm high fence for $1200. Re: Colorbond Fencing- cost???? 9Jun 21, 2012 10:26 pm MattyT I just got quoted $103p/m for the supply and install of 1800mm colorbond, raked with TP sleepers underneath... this is in Canberra, so I guess prices would be a bit higher, but $103p/m seems a bit steep, doesn't it? The sleepers under would be adding the cost, if that is there to be a retaining wall that is the reason it is more epensive Re: Colorbond Fencing- cost???? 10Sep 08, 2012 4:31 pm Have a guy in western sydney that quoted me $53 a metre if striaght run 1.8m in woodland grey Check out our blog below! We are using iDraft and Cozzcorp for our build http://ridgydidge1460.blogspot.com Plans: http://www.idraft.com.au Construction: http://www.cozzcorp.com.au Re: Colorbond Fencing- cost???? 12Sep 10, 2012 10:17 am If you can pm me the details also that would be great Re: Colorbond Fencing- cost???? 13Sep 10, 2012 4:16 pm Hi Banksy, Will be great if you could share the details for the fencing guy with me too Cheers KK Re: Colorbond Fencing- cost???? 15Sep 10, 2012 7:48 pm Ron 0400812093 Hes extremely reliable, i got him as a referral from a good friend who is a porperty manager for a large rent roll, uses him regularly with no issues Check out our blog below! We are using iDraft and Cozzcorp for our build http://ridgydidge1460.blogspot.com Plans: http://www.idraft.com.au Construction: http://www.cozzcorp.com.au Re: Colorbond Fencing- cost???? 17Sep 11, 2012 11:46 am building on a rear block should i replace my back boundary fence before or after my new home construction? just worried that the construction might damage and dirty the fence. but after construction, narrowed access...?? please advice thanks@! Re: Colorbond Fencing- cost???? 18Jul 11, 2013 7:56 am Anyone know how it compares to cost of hardwood paling fence? Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10208 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2877 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18563 |
