Browse Forums Building A New House 1 Apr 30, 2012 9:47 am Hi All We are at the 'building permit' stage of our renovations/extensions but as I'm a first home owner, I'm really confused as to what to do & when. We have a layout of the house but no internals drawn. Do we get builders to quote without internals and who draws up the internals for us? Or are we supposed to get everything drawn up for us and specified before builders quote. Is it a draftsman or a designer that draws up internals? Also, when do we submit for the building permit - I'm thinking after the building quotes because we may need to redraw things based on affordability? Help please! Re: Confused about when to get builder to quote 2Apr 30, 2012 10:22 am A competent draftsman will be able to give you a good idea of what your place will cost based on what you tell him/her. A rough plan or sketch showing the rooms and general layout will suffice for this. After this you get them to draw up the proper plans for the DA including site plan, floorplan, elevations etc. This should cost you probably $2,000 - $3,000 depending on where you are and whether it is single or double storey and how complicated the job is. Engineering drawings and surveys are extra. The draftsman should be the one who lodges all documents and plans to the council just to make the process easier for you. A lot of builders will only quote on a job once they have proper plans to work from including the structural drawings but they may be able to give you a ballpark figure from your basic sketches subject to the final drawings. Stewie Re: Confused about when to get builder to quote 3Apr 30, 2012 1:37 pm Hi Stewie, Thanks for that! I am trying to get together the comprehensive process list of what gets done & in what order, can you help guide me: 1. Site plan (Architect/Draftsman) 2. Floorplan (Architect/Draftsman) 3. Elevation plans (Architect/Draftsman) 4. Land Survey (Surveyor organised by Architect/Draftsman) 5. Energy rating report (Energy company) 6. Planning report res code 54 (lodged by Architect/Draftsman) 7. Town planning/Council permit application (lodged by Architect/Draftsman) 8. Soil test 9. Working drawings (Architect/Draftsman) 10. Structural/Civil engineers drawings (Engineer) 11. Internal drawings (Draftsman/Cabinetmaker) 12. Builder contract 13. Building permit application (lodged by Architect/Draftsman? or is it Builder?) What have I missed so far? Many thanks! Re: Confused about when to get builder to quote 4Apr 30, 2012 4:53 pm Jean_home I agree with Stewie, I often give estimates based on the level of drawings you have now and then follow up with an exact dollar quoatation once your documentation is complete. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Confused about when to get builder to quote 6May 03, 2012 11:15 am Unless you have some very specific needs I would get the draftsmen to show the areas of joinery on his floorplans and then do the detailed design yourself in conjunctioin with a cabinet maker. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Confused about when to get builder to quote 8May 04, 2012 6:41 am get your soil test done ASAP, it doesn't cost much ($200-$300), but you will know upfront if you will have majot problems with footings. From the soil test, you can get a ball park figure how much concrete and steel will be needed based on Australian Standards, (subject to final engineering of course). A talking dog, don't worry what it's saying, it's amazing it can even speak. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8314 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20912 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14318 |
