Browse Forums Building A New House 1 Mar 07, 2008 8:25 am Hi all
Just thought I would get some thoughts fron you guys about the issue I have with my front projection fixed retreat windows. These windows directly face the street and are virtually next to each other. The issue is the corner window has a flat cross bar whilst the larger window to the left has a join in the cross bar. The builder says its because the larger window is made in three bits whilst the corner one is in one. I have looked at other houses near mine with the same facade and these windows match IE: Not diffrent like mine. Do you guys think this looks ordinary as they look diffrent when standing in front of them. As it is at the front of the proerty I am concerned. It is in the hands of the building manager as the site supervisor says he is not authorised to change it. Any advice would be greatly appreciated Pic of two windows from a distance http://i263.photobucket.com/albums/ii125/stevecphotos/2FixedFrontRetreatWindows.jpg Close up of two windows http://i263.photobucket.com/albums/ii125/stevecphotos/2FixedfrontretreatWindowsprofiles.jpg Re: Issue with front facade windows 2Mar 07, 2008 8:58 am It would bother me, but I can be terribly anal.
I think truly it isn't so bad, nobody would ever ever notice it, nobody but you that is! It sounds to me like there's not much that can be done anyway? It does seem misleading though and something you should have been told. Re: Issue with front facade windows 3Mar 07, 2008 9:44 am I didn't even notice it until I looked at the second picture and that is only because you pointed it out......It probably wouldn't bother me.
It is your house though and you will have to live with it for however many years so you need to be sure you will be happy with the end result. Re: Issue with front facade windows 4Mar 07, 2008 9:49 am I also didn't notice until you pointed it out, however, that does not mean it is excusable. You are entitled to get the windows you have paid for...its your house. If you are not happy then I would take it further.
Good luck ![]() Re: Issue with front facade windows 5Mar 07, 2008 12:17 pm I also couldn't see the problem. I had to read your message again to clarify for myself where I should be looking. So if your concern is that it is terribly obvious that its different and it will be the first thing visitors notice - I don't think you have a problem. But if it's something that will annoy you anyway, get it fixed. Re: Issue with front facade windows 6Mar 07, 2008 12:21 pm I think you can get away with it as one is a corner feautre window, and the eye is drawn to that.
I too had to look again to see what the problem was, but if its annoying you now get it fixed, or you will hate it forever. Paula Re: Issue with front facade windows 8Mar 07, 2008 12:55 pm Steve, easy question....what is on the display home?
IF it is a 3 part window and it's meant to be that way, then the display home should be the same. If not, bring it up with the building manager again. Good Luck! Re: Issue with front facade windows 10Mar 07, 2008 3:09 pm Personally it wouldn't worry me but it wouldn't hurt to speak with the window manuf. directly & ask the question.
[If you have another pic. showing the frame work above the window on that corner I'd be interested from a design point of view] Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Should be something they come out ASAP to rectify, looking at the neighbors it would appear yours has a leak as I would expect theirs also to be filled if it was seeping… 2 3213 it's going to be hard to inspect, and more importantly it's going to be hard too keep that area clean of any debris or food for termites, and it will provide a nice shaded… 1 1630 I thought he already paid to the neighbours. Because the fence was not too old. Now after 1 year I got a call from owner and ask for the money. 4 2164 |
