Browse Forums Building A New House 1 Apr 12, 2012 8:52 pm I have a question about pools; I was sure if it belonged in the pool section or in here because it's mostly related to the initial house building stage. Anyway, I'm wondering how common it is to buy land large enough to allow for installation of a pool a few years after the house has been built? Also, are there special council regulations you need to check to make sure you're allowed to install a pool on the land in question? If anyone has been in this situation, how much land space have you dedicated to a future pool? Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Land size to allow for pool at later stage? 2Apr 13, 2012 6:04 am Access is probably the most important aspect, being able to excavate with machinery and remove spoils with ease will keep price down. (if designing a new house include a roller door at rear of garage if side access not possible) Easements such as sewer or storm water will affect pool location, in regards to size well that is dependent on what sort of pool your after. They can be designed to fit in any space. Landscape Design & Construction http://cherub.squarespace.com/ Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7608 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3697 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3574 |
