Browse Forums Building A New House 1 Apr 06, 2012 4:55 pm Hey, Our fridge just died, any we are going to buy a new one. Now one model we are looking at is 1m wide and needs 1cm either side so a total of 1020m. Our house is currently being built (WA so double brick) and while there is no grey/white plaster on yet the width of the fridge recess is 1100. Do you think the plaster would be greater than 4cm deep?? The more I talk about it the more nervous it makes me that i'll be cutting it too close any advice? Re: Depth of Grey and White Plaster on internal Bricks 2Apr 06, 2012 6:10 pm Edit: nevermind... Some people apparently have nothing better to do than comment on other people's sigs. Re: Depth of Grey and White Plaster on internal Bricks 3Apr 06, 2012 6:21 pm As the op is in wa they are not using plaster board. The float and set used over internal walls is only about 10mm. Your fridge space is plenty. Dimensions shown on plans in WA are to the brickwork. You need to allow for the render thickness when working out furniture or fixings. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Depth of Grey and White Plaster on internal Bricks 4Apr 11, 2012 12:02 pm chippy As the op is in wa they are not using plaster board. The float and set used over internal walls is only about 10mm. Your fridge space is plenty. Dimensions shown on plans in WA are to the brickwork. You need to allow for the render thickness when working out furniture or fixings. thanks for that. I got the fridge, and the body is a few mm smaller than the doors too so it should fit easy now. The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27310 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5421 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5026 |
