Browse Forums Building A New House 1 Mar 30, 2012 2:45 pm I am getting quotes for installing a double wing gate, the Merbau ones look really nice and will cost $1500, if I choose timber to do the same style of gate (horizontally slatted) it will cost $950. I intend to go with timber coz it's cheaper, my question is are there any timber paint that will give me the oily colour effect of Merbau? Is the paint expensive and how many times of coating I need to do for timber? The size of the double gate is about 2m long and 1.95m high. Thanks for your advise! Re: Timber gate vs Merbau gate 2Mar 30, 2012 3:30 pm If you have a look on my thread titled "Owner building paal camden in lower hunter valley" you can see what a merbau tint looks like on cedar - 3 coats, thought the garage door has only had one coat so far. I've used Wattyl water based decking oil that has the merbau tint put into it - it means that you really need to apply it carefully as brush strokes or drips really become more obvious with each coat. Hope this helps a bit.... Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Timber gate vs Merbau gate 3Mar 30, 2012 4:06 pm lynny-jane If you have a look on my thread titled "Owner building paal camden in lower hunter valley" you can see what a merbau tint looks like on cedar - 3 coats, thought the garage door has only had one coat so far. I've used Wattyl water based decking oil that has the merbau tint put into it - it means that you really need to apply it carefully as brush strokes or drips really become more obvious with each coat. Hope this helps a bit.... Your window frames and garage timber door look awesome! What a lovely house, thanks for the info. Re: Timber gate vs Merbau gate 4Mar 30, 2012 5:31 pm citystop I am getting quotes for installing a double wing gate, the Merbau ones look really nice and will cost $1500, if I choose timber to do the same style of gate (horizontally slatted) it will cost $950. I intend to go with timber coz it's cheaper, my question is are there any timber paint that will give me the oily colour effect of Merbau? Is the paint expensive and how many times of coating I need to do for timber? The size of the double gate is about 2m long and 1.95m high. Thanks for your advise! Hi citystop, what timber do you get for $950? Seems a pretty big gap there in the prices. If you do want merbau look, you can try dwd intergrain tinted to merbau. tends to last a bit longer that deck oil especially on a gate where water doesn't sit. Re: Timber gate vs Merbau gate 5Mar 30, 2012 11:26 pm mgilla citystop I am getting quotes for installing a double wing gate, the Merbau ones look really nice and will cost $1500, if I choose timber to do the same style of gate (horizontally slatted) it will cost $950. I intend to go with timber coz it's cheaper, my question is are there any timber paint that will give me the oily colour effect of Merbau? Is the paint expensive and how many times of coating I need to do for timber? The size of the double gate is about 2m long and 1.95m high. Thanks for your advise! Hi citystop, what timber do you get for $950? Seems a pretty big gap there in the prices. If you do want merbau look, you can try dwd intergrain tinted to merbau. tends to last a bit longer that deck oil especially on a gate where water doesn't sit. It's quoted on raw timber that's used for paling fencing, not sure yet if it's treated pine slats. I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12127 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9075 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6696 |
