MyHome1
Good and Bad - I got Occupancy Certificate issued however with Building Order to 1.Fix AJ's, 2.Weep Holes and 3. To get Engineer report that brick work is good. 1&2 is oke I can fix over killing is item3. Eventhough I tried to give them regiter brick layer letter but not accepted they are strict to get eng report. I am trying hard. Is any body knows who can give me engineering report? I am located near Wrribee.
Hi Branko,
Could you please kindly help me to get cancel this order from Surveyor. Please call and discuss with xxxxx and advise me the outcome.
I was assisting OP with problem with building surveyor and I got the result we wanted: the ridiculous order was lifted
what did it? here:
Hi xxxxx
I am assisting xxxxx with some of the defects on his home and require further information as to why you would require a letter from structural engineer regarding non structural brick veneer wall which to mere is perfectly functional. It seems overkill and a waste of money. I am building expert and I don't see any structural issues. Building Commission has seen it and did not recommend any action
Hi xxxxx
I have not received a direct reply to my email but I believe that you are acting outside provisions of Cl. 24(2) of the Building Act 1993 insofar as you are requiring greater standards than required. Any breaches of Building Act by RBS may be subject to inquiry into conduct under s 178(d) of the same.
Please advise your reasons why you have reasonable grounds to demand an engineering certificate?
We have received the below email from Branko Mladichek regarding your property. What we will do is forward the order on to the Building Commission for their advice regarding the issues.
and
Talk is cheap, I get results!
