Browse Forums Building A New House 1 Mar 19, 2012 3:42 pm Hi guys, For our acreage build we are required to provide potable water and pressurised water for use during construction. We are not keen on installing our rhino rainwater tank early as it could very easily get damaged by the builders. Does anyone have any recommendations on what options we have here? Should be buy some sort of temporary solution or is there somewhere we can hire this from at a reasonable price around Brisbane. We have received one quote so far and it looks like it will cost us about 5k to hire for the 4-5 month period. Thanks for your help. Re: Acreage build temporary water solution 2Mar 19, 2012 4:31 pm It would be cheaper to buy a 5-10,000 poly tank now (less than $2,000). You could then use this as an initial settlement tank to keep your main tank cleaner after you move in The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Acreage build temporary water solution 3Mar 19, 2012 4:46 pm yes bashworth....thats what we had planned to do to. also give a bit of extra time to save for the big tank. Re: Acreage build temporary water solution 4Mar 19, 2012 8:50 pm Wow we were lucky, we only had to provide water for the build side of things so we just gave them a tap straight from the irrigation pipe, that's not potable water. But they did not ask for potable, we also have rain water if they really wanted it to drink Re: Acreage build temporary water solution 5May 07, 2012 5:20 pm Hey guys, we've started a blog to track our build: http://blog.mikeandkerryjane.com/building/ 1 4560 Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3938 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1850 |
