Browse Forums Building A New House Re: Possible location for external gas bayonet (for BBQ) [pic] 2Feb 29, 2008 11:36 am What size BBQ are you going to have?
If it's one of those new monster BBQs with 6 burners, wok burner etc - I'd put it at A - more room. A small 4 burner BBQ then B - but the glass might get a lot of fat splatter. After 4 years - we're in! Re: Possible location for external gas bayonet (for BBQ) [pic] 4Feb 29, 2008 11:41 am Thanks. The problem is I DONT know where to put the BBQ!!! I am not really into BBQ, probably once in a month. I will probably get a small (4 burner) BBQ.
Anyone else? Re: Possible location for external gas bayonet (for BBQ) [pic] 5Feb 29, 2008 11:45 am point B
possibly 'storing' when not in use at point B but when in use have the flexibility to wheel it between the pier and point B. In that way the fat splatters will go out in the garden not on the brick walls and glass sliding door. Re: Possible location for external gas bayonet (for BBQ) [pic] 6Feb 29, 2008 11:56 am commodorenut - I thought A was along the brick wall? (I may very well have read the plan incorrectly) After 4 years - we're in! Re: Possible location for external gas bayonet (for BBQ) [pic] 7Feb 29, 2008 11:57 am Put it half way between A and B
Re: Possible location for external gas bayonet (for BBQ) [pic] 8Feb 29, 2008 11:57 am It is starting to make sense now, with the "storing" and "cleaning" ideas.
Could i put the gas bayonet at the far left of point A. In this case, i will roll the BBQ unit to the left end of the alfresco, so the fat will go to the garden? If not in use, the BBQ will just sit in point A. How far is the gas tube/hose can be extended from the base (gas bayonet)? Is it a good practice to disconnect the bbq from the bayonet each time after use? Or it doesnt matter? Huge thanks for the replies.. PS: Mark, the sliding door open to both sides. Re: Possible location for external gas bayonet (for BBQ) [pic] 9Feb 29, 2008 11:58 am ![]() commodorenut - I thought A was along the brick wall? (I may very well have read the plan incorrectly) I was just about to post the same question but then CN's post dissapeared. Good trick that. ![]() ![]() Re: Possible location for external gas bayonet (for BBQ) [pic] 10Feb 29, 2008 11:58 am Yeah I realised it was brick not glass, and went to edit but stuffed it....
How big is the area at point A? It may be more convenient to leave it at A - it's more rotected from the wind & rain (so you can BBQ regardless of the weather) and if there's enough room to be at least 300mm away from the nearest glass, then the heat won't affect it (I'm guilty of breaking a kitchen window with BBQ heat....) If the area at A is too small, then B would be the best bet. If you leave the BBQ at A, then you'll find it may turn into a convenient outdoor storage table for all manner of cricket bats, tennis racquets, beer cans...... Re: Possible location for external gas bayonet (for BBQ) [pic] 11Feb 29, 2008 12:00 pm ![]() Put it half way between A and B. Point D? Re: Possible location for external gas bayonet (for BBQ) [pic] 13Feb 29, 2008 5:59 pm ![]() The length of "point A" wall is 2 meter (the dimension of the alfresco is 3X5.3m). Thanks. If you have 2m of wall to locate it on, and back the BBQ up to, then I'd be looking to put it there. Re: Possible location for external gas bayonet (for BBQ) [pic] 15Feb 29, 2008 6:38 pm Hi Oznow
I would look at it from a different perspective. I would place the bayonett as close to the corner between B&C as possible and have the back of the BBQ facing out (ie not backing against a wall). That way when it is in use all fumes, steam, smoke & grease should escape past the ceiling. If you put it at A I would expect you will end up with a dirty big mark on the ceiling above. As long as you buy one with wheels on the one end you could always store it at A. Anne Grandview 36 on Beautiful Bribie Site Start Dec 5th 2007 Projected completion May 12th 2008 NOPE Handover 24th June 2008 Moved in 11th July 2008 Wating on one final thing - Still - Oct 2009 Re: Possible location for external gas bayonet (for BBQ) [pic] 16Feb 29, 2008 6:48 pm I absolutely concur with the previous post. My cousin has an alfresco and a BBQ under it in probably the equivalent of either point A or point B and their ceiling has a dirty great charcoal mark on the ceiling above the BBQ that everyone notices.
Only use your BBQ under the alfresco ceiling when it is raining. Re: Possible location for external gas bayonet (for BBQ) [pic] 17Feb 29, 2008 7:06 pm We have a capped gas point going on the outside pole supporting the alfresco roof - I want to eat under my alfresco area not deal with fumes and smoke. Fi has moved in!! Re: Possible location for external gas bayonet (for BBQ) [pic] 18Feb 29, 2008 9:35 pm Or build in a BBQ as a feature and have a range rood installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ![]() ![]() ![]() Paula Re: Possible location for external gas bayonet (for BBQ) [pic] 19Feb 29, 2008 10:27 pm Make sure that your BBQ is rated for Natural Gas, and not a normal BBQ. If you dont you will need a new BBQ in 12-18 months.
Also, you may find that it is a requirement that the BBQ be FIXED to the house in order to have it connected to natural gas. Adrian B Re: Possible location for external gas bayonet (for BBQ) [pic] 20Mar 01, 2008 1:04 am Seriously use a gas bottle.
Then you can put it wherever you want depending on prevailing conditions. Forgetting about the size for now, a detention tank is applicable to a Premissable Site Discharge (PSD) flow rate, the very reason for their requirement. Check with the… 6 2487 ![]() yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 2622 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 6010 ![]() |
