Browse Forums Building A New House 1 Mar 11, 2012 4:28 pm Hi there, Building in Kellyville (Willcox Cres) and require a 9,000 ltr tank. We have recycled water so the tank requirement daft. Spoke to council, they say it's a developer requirement. Developer says its council. Spoke to the BASIX enquiry line & they indicated that the water tank isn't needed with recycled water. Any advice or similar experience from anyone would be greatly appreciated. Thanks. ... and here we go again Re: BASIX & water tank requirements 2Mar 11, 2012 6:56 pm Yeah we got the same set of confusing replies. Its actually in our contract for land, a water tank for retention, and a rain garden. It was part of being a complying development from the nsw govt. Is it in your land contract? BASIX & water tank requirements 3Mar 11, 2012 9:25 pm It's in our land contract too. But the developer says it was a council requirement which turns out to be incorrect. 9,000 ltr is a lot of water to only be used on a garden when there's recycle water. According to the BASIX hotline the developer has stuffed up. Seems to me a lot of development where each property is having to fork out $10k for no gain. Wonder if it's worth fighting ? Thanks. ... and here we go again Re: BASIX & water tank requirements 4Mar 11, 2012 10:31 pm nadhome It's in our land contract too. But the developer says it was a council requirement which turns out to be incorrect. 9,000 ltr is a lot of water to only be used on a garden when there's recycle water. According to the BASIX hotline the developer has stuffed up. Seems to me a lot of development where each property is having to fork out $10k for no gain. Wonder if it's worth fighting ? Thanks. I'm with you. My father in law is also building and shaking his head over the 10K quote. I'm sure we can get the builder onside as well. Where do we take the fight to? Should I call my lawyer? I haven't exchanged the contract yet, as I only paid the deposit on Friday... BASIX & water tank requirements 5Mar 12, 2012 11:29 am Been doing some tracking down of information this morning and have established that the Baulkham Hills council development control plan for the area, page 26, Part E section 17 states under the heading 8.1.6 "Storm water management" ; "a) each dwelling shall have a minimum 9,000 litre rainwater tank (or equivalent volume of multiple above-ground tanks) connected to its guttering" The developer appears to have mirrored this requirement within the land contract. I don't think the tank requirement in this case has anything to do with BASIX & water saving, rather the controlled flow of water into storm water. Trying to get clarification from council today on this as looking at the developments submitted in the area not everyone has a tank. Which leads me to believe it may have something to do with an easement at the back of our block. Would be good if someone at council could provide a straight answer. Not holding out on the hope of any signs of life there ! ... I really should have purchased a pre-existing home instead of subjecting myself to the brain damage of building ... and here we go again BASIX & water tank requirements 6Mar 12, 2012 2:26 pm Spoke to council & finally got hold of someone with some grey matter. It is as suspected for flood control into storm water. It was either the 9,000 litre tanks at $10k or detention pits at $30k. Council stipulated the tanks as the cheaper option to control the flow of water so the guys down the lower part of the street didn't receive all our water at once during heavy rain. Would have been nice if this was explained up front instead of leaving us guessing. Thanks. ... and here we go again If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17541 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10835 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1673 |
