Browse Forums Building A New House Re: Critique my Plans 2Mar 09, 2012 2:26 pm I'm assuming that North is to the rear RH side? Is there really a need for two showers downstairs? Otherwise I'd look at turning the powder room into the ensuite by moving the toilet to where the small linen cupboard is ( with access to the toilet from the hall as well as the ensuite)and using the ensuite space in the Master-encompassing the current WIR but making it the width of the Master but shallower would add space to the Master itself... Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Critique my Plans 3Mar 09, 2012 2:38 pm Rough and ready as I don't have a program other than paint but something along these lines... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Critique my Plans 4Mar 09, 2012 2:39 pm North is facing directly to the right of the plan. Yes I was debating the need of that 2nd shower upstairs, I could probably delete it but would prefer to keep the pwdr room with toilet and perhaps just make it smaller and somehow make the WIR and/or Ensuite a bit bigger. Build Thread: viewtopic.php?f=31&t=57639 Re: Critique my Plans 5Mar 09, 2012 2:40 pm It also allows you to move the Master door down opposite the stairs-giving more wall space to the meals area. Use a lockable cavity slide between toilet & ensuite..still have a great size ensuite with double vanities and mor robe space! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Critique my Plans 6Mar 09, 2012 2:42 pm Oops-upstairs! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Critique my Plans 7Mar 09, 2012 2:54 pm Ok-what about this....put powder room toilet on other wall, swapping door position. Powder room vanity then creates nook in ensuite for toilet to be tucked away out of direct sight... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ By the way- I like the rest of your plan! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Critique my Plans 9Mar 09, 2012 3:12 pm My only comment on that would be the wasted space leading to the powder room-and to make sure that whatever way you go ensure that soundproofing is used on the walls! Avoid the * ahem* noise factor of people using ensuite & powder room! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Critique my Plans 12Mar 09, 2012 9:45 pm ^^^ Dan-laundry is actually DOWNstairs....split level home! Plucka-swap the vanity & toilet position in that powder room because it would be too squeezy to get past loo to the vanity otherwise. Back the toilet onto the common wall with the ensuite shower....I like! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Critique my Plans 13Mar 10, 2012 6:16 am Deemaree ^^^ Dan-laundry is actually DOWNstairs....split level home! Plucka-swap the vanity & toilet position in that powder room because it would be too squeezy to get past loo to the vanity otherwise. Back the toilet onto the common wall with the ensuite shower....I like! yes do that, that would be a better use of dark corridor space Re: Critique my Plans 15Mar 12, 2012 8:39 am Springfield, Brisbane. Build Thread: viewtopic.php?f=31&t=57639 Re: Critique my Plans 16Mar 13, 2012 7:49 pm Deemaree make sure that whatever way you go ensure that soundproofing is used on the walls! Avoid the * ahem* noise factor of people using ensuite & powder room! Yes, Dee has been advising me on this recently. Dee, I am wondering if you have had a bad experience along these lines?!?! SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Critique my Plans 17Mar 13, 2012 8:11 pm Have been in too many houses where privacy is non-existent! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6884 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13771 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4480 |
