Browse Forums Building A New House 1 Mar 08, 2012 3:44 pm Hi We have had 56 days of rain on site since our frame went up, basically our home has not been dry since late November due to all the bad weather. I am concerned now about our top floor flooring, they say the flooring is rated for 3 months continual water, well in some spots it has not dried out at all, it has not been given a chance. We are still not fully sealed up yet thanks to the rain. What effect do you think this will have on our top floor flooring? Re: Rain, what long term effect does it have on the top floo 2Mar 08, 2012 3:58 pm I was worried as well, it was exposed for couple of months my floor has dried up once the roof went in. I used to push the water out with a huge sweeper. What I suggest is ask your builder to do a proper sanding of the floor before the floor covering goes in. Also I sprayed some exit mould on few places before the plaster (not sure if that helps) Orchid 4200 with Burbank: Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=53034 House Built in 7 Months and 2 weeks Re: Rain, what long term effect does it have on the top floo 3Mar 08, 2012 4:16 pm I read this a while ago. http://realestate.msn.com/article.aspx? ... d=19423888 It's american though.. so their standards and build are a bit different. Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 493 Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 3436 Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 3521 |
