Browse Forums Building A New House 1 Feb 28, 2008 11:18 am Re: another overhang thread: not wood frame but the sliding door 2Feb 28, 2008 4:21 pm I'd be more concerned about the roof not being on.
But to answer your question, unless the bottom track is fully supported where the rollers bear [run] then you could have problems. What is the storey with the roof - I assume it's a scheduling stuff up. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: another overhang thread: not wood frame but the sliding door 3Feb 28, 2008 4:57 pm Peter wrote
Quote: What is the storey with the roof - I assume it's a scheduling stuff up. Naahhh - They are only expecting slashing rain from the horizontal direction, not from above Re: another overhang thread: not wood frame but the sliding 5Jun 10, 2010 12:49 am Hi I have the same issue like you, the frame of the sliding door at the left 10mm off from and the right side 20mm off from the slab, not sure have you figured out the issue? what the SS said to you? Re: another overhang thread: not wood frame but the sliding 6Jun 10, 2010 9:31 am Hi Oznow. I just wann confirm that it is just the Sliding door piece that is hanging of the slab, and not any part of the frame. You used the sliding door frame so this confuses me a bit. Basically if it is just the sliding door that is hanging from the slab this in normal. Once it is bricked up the bricks would go underneath track and hold it up. Re: another overhang thread: not wood frame but the sliding 7Jun 10, 2010 2:08 pm borg Hi Oznow. I just wann confirm that it is just the Sliding door piece that is hanging of the slab, and not any part of the frame. You used the sliding door frame so this confuses me a bit. Basically if it is just the sliding door that is hanging from the slab this in normal. Once it is bricked up the bricks would go underneath track and hold it up. I agree, normal. The sliding door overhangs and the brick sill supports it. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: another overhang thread: not wood frame but the sliding 9Jun 11, 2010 1:12 am Hi everyone Sorry i probably confused everyone about the overhang sliding door, for my understanding, there is a gap between the brick and slab, the sliding door sit on the middle between brick and slab, is that correct? my question is .. my sliding door frame is hanging one side which is off the slab and sit on the brick sill at the other side, i can feel the door frame could slightly bend or sink one side if i standing on it. somehow the gap is one side bigger than the other side, 10mm at the left and 20mm at the right, which mean you can see small gap and going big and bigger. it really bother me everytime i see it. can anyone tell me is this normal? Re: another overhang thread: not wood frame but the sliding 10Jun 11, 2010 8:16 am Not quite getting your picture... the sliding door sill should rest a small amount on the slab along its length... the bit that sits out is supported once the bricks are in place. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7823 My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 700 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11121 |
