Browse Forums Building A New House I still dont get this photo thing! 2Feb 26, 2008 8:49 pm i dont seem to be able to add an attachment
step by step advice would be very appreciated when I use the "add attachment. brouse feature, I navigate to my photo, and click on upload...and then nothing happens! Re: my DH build us a frame! 6Feb 26, 2008 9:15 pm zonk, re-copy and insert the image from photobucket...the file (as you have inserted) is not complete. Re: my DH build us a frame! 8Feb 27, 2008 9:06 am Most impressive! Did he build the concrete swimming pool too?
I presume you guys have an OB cert? Was this easy to get? Whereabouts in Melbourne are you building? We are in Langwarrin. Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: my DH build us a frame! 9Feb 27, 2008 9:41 am Looks fantastic with the pool in position, We are doing our pool at the same time as the excavation (access point of view)
Quote: I presume you guys have an OB cert? Was this easy to get? I havent done any researh into this part of my build yet. What is this?? Paula Re: my DH build us a frame! 10Feb 27, 2008 10:32 am Paula Quote: I presume you guys have an OB cert? Was this easy to get? I havent done any researh into this part of my build yet. What is this?? Owner builder certficate. Only needed if you yourself are the primary contractor. Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: my DH build us a frame! 12Feb 27, 2008 12:16 pm we are in rowville.
yes the pool had to go in first as it is in the courtyard, "u" shaped floor plan we do have an OB certificate, very easy to obtain through the housing commission...only $75! and an application form to fill in. my DH is a bricklayer and usually works on mirvac sites so he has constant access to chippies, roof tilers plumbers etc etc they all get to know each other on these sites (eg waverly park) I see directly below this as I type written in orange "add an attachment" then file name and browse. I tried using this but cant get it to work so photobucket it is for now. but my pics take so loooong to upload there This is 100% true. You can not hang anything on steel frames. very frustrating 8 8021 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28320 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4458 |
