Browse Forums Building A New House 1 Feb 21, 2012 12:21 pm Hi everyone, quick question... When does the temp fence usually get taken away.. Reason im asking is because we have presentation on Thursday and the fence has just been taken away? Handover we are hoping will be the end of next week. Re: temp fence around house 2Feb 21, 2012 8:03 pm I assume it's generally just before handover as they would have to clear and level site before them You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7031 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4671 Building a fence now will help limit people dumping rubbish and soil on your property. Many houses in suburbia on small lots have fences up before a build. I moved into a… 1 4396 |
