Browse Forums Building A New House Re: 31C High Ceiling 3Feb 17, 2012 8:35 am 31c is a WA way of saying it - 9ft ceilings to the rest of us? or 2700mm. I am a huge fan of high ceilings and I have 9 ft ceilings throughout my single story house. I would do the whole house. Have not found bedrooms too cool in winter - admittedly I live in hot dry area of Australia. We run r/c air con for about half hour before going to bed on a really cold night and thats it - do not have an electric blanket or any other bedroom heating and is fine. Re: 31C High Ceiling 4Feb 17, 2012 9:02 am For our home we made the garage, front entry and master bedroom 31c, originally for the purpose of the front façade. However it now means we can comfortably fit a taller vehicle in the garage, plus I'm going to love having high ceilings in the bedroom. In WA display homes I've found the most popular choice of late is for high ceilings usually just in the master bedroom, entry, and main living areas. The option is there to have the whole house, if you can afford the extra outlay and possible heating/cooling costs that come with it. Re: 31C High Ceiling 5Feb 18, 2012 6:53 pm If we had the money, we would have done the whole house! We couldn't afford either, but it was more economical to increase the height of the whole house then just the living areas. From memory it was going to cost $8000 or so for the living, $12000 for the whole lot?! These are just guestimates, it was a long time ago when we discussed it with the builder! Going to the display homes recently, all the mid to upper end have the whole house at the higher ceiling. Good for adding ceiling fans!!! No banging heads and nasty accidents when turned on (my 6'6" husband has had some very near misses with fans that are on in normal ceiling homes!) and having fans is cheaper then running the aircon constantly! I like the space it gives to a room, but if I were to do it, I would also increase the height of the door ways. Unfortunately we couldn't afford to do either, but we did manage to get a freebie from the builder and our alfresco is recessed with a 31c ceiling and we will be putting a fan in there! It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8281 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39749 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 |
