Browse Forums Building A New House Re: Who else is building with Eden Brae? 10981Dec 10, 2014 8:45 pm Hi Nimsy, Thanks for your feedback. I believe the $2085 is an add-on price to the Slimline Tank that you already have. Assuming that the Slimline upgrade cost $1300 so the total add-on is $3385 from standard round tank. That figure is pretty much in line with the quote that others had posted. I believe you can specify where you want the tank to be installed. I've seen videos that you can have the tank installed under your front yard. That should give you plenty of room to fix the tank in case anything happens. Plus if it leaks the water could leak straight into the gutter. The other downside to underground tank is that, in case your yard is flooded and submerging the tank's manhole, the dirty soil water could sip through the manhole and into the tank. The dirt may get pump into your toilet after flushing and when washing cloths and makes things look dirty. I am unsure if having a underground water tank would increase the aesthetic value of the house. Should I be spending the money on tank or elsewhere? Re: Who else is building with Eden Brae? 10982Dec 11, 2014 7:05 am Hi guys, I can provide a little more information on this shortly re: underground tank as we have selected this option. Unable to get to my paperwork at the moment. Standby. Re: Who else is building with Eden Brae? 10983Dec 11, 2014 9:44 am Hi Guys, Yes, we have upgraded to the underground aquapod / aquacomb 3,000L rainwater tank, costing $3,100 (upgraded from the standard round above ground rainwater tank). We chose this option over slimline and the round options as for the reason you mention above. Aircon to be installed later, not much space in back yard, slimline can't fit down the side of the home etc. Obviously there are risks associated, as you rightly mention above. But these tanks have been specifically designed and tested for underground use. I don't know which brand / supplier Eden Brae use. It would be good to know...this might help alleviate any concerns...I might do some more digging...what this space! Initially the underground tank was placed under the garage. We were then later advised it was incompatible with construction and had to be relocated to sit under the living area (as per the first image - blue boxes). We weren't too worried I guess (not much choice!). We just made sure the pump wasn't positioned in the way of a window or in the way of future installations, for example, we are planning to put a gas fireplace on the living external wall (between the windows). Here are the only references I have of the tank from Eden Brae. The first image is terrible quality, we asked for another clearer copy but they did not resupply. You will notice the tank positioning still differs from the final draws (which were only re-supplied to us yesterday). The final plans suggest the tank is still in a square shape format...We will need to query this... A work in progress still...but hopefully this helps some of you? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who else is building with Eden Brae? 10984Dec 11, 2014 5:25 pm Hi Shayne, Thank you so much for the information. That really give us and idea on what to expect. We will raise this in our color appointment tomorrow. Hopefully we could get for a decent price for it. I did a search for "Aquacomb" and the this website came up. http://thevlpgroup.com/cortese/remtec/index.html Re: Who else is building with Eden Brae? 10985Dec 11, 2014 8:48 pm Hi amazingk, Okay, I've gone back through all my folders here tonight and can confirm that Eden Brae do use RemTec for the Aquacomb systems. I found this brochure in my files (which is thankfully available online too): http://thevlpgroup.com/cortese/remtec/i ... ch2011.pdf All the best for your colour selections tomorrow! Keep us posted! Cheers Re: Who else is building with Eden Brae? 10987Dec 15, 2014 7:13 pm It looks similar to the one we picked - just a different colour. What is it? Re: Who else is building with Eden Brae? 10988Dec 15, 2014 7:21 pm Re: Who else is building with Eden Brae? 10989Dec 15, 2014 7:38 pm Could you kindly tell me what code your choice has? I think Di Lorenzo have delivered and installed a darker version of this tile Re: Who else is building with Eden Brae? 10990Dec 16, 2014 6:30 am Thanks Shayne. Was definitely not that This is just a ceramic tile in the builders range. Re: Who else is building with Eden Brae? 10991Dec 16, 2014 6:32 am kim_kdr It looks similar to the one we picked - just a different colour. What is it? Hi Kim Could you please let me know what the tile code is for your tile that looks similar? Re: Who else is building with Eden Brae? 10992Dec 16, 2014 7:04 am ssjmark kim_kdr It looks similar to the one we picked - just a different colour. What is it? Hi Kim Could you please let me know what the tile code is for your tile that looks similar? Ours is porcelain so sounds like a different tile anyway. Re: Who else is building with Eden Brae? 10993Dec 17, 2014 10:43 pm Shayne you're information is so helpful for everyone. It really does make it easier. Can you link your blog in here I can't see it if you have in your signature when I'm on my phone. I started a blog for the same reasons as you. Lack of detailed knowledge on thd process. www.drysdaletheridge.blogspot.com Eden Brae Drysdale 27 | The Blog Re: Who else is building with Eden Brae? 10994Dec 17, 2014 11:59 pm Hi Renski! Very much appreciated Funnily enough, your blog has helped us through our build journey! So thank you! It's - www.edenbraelivingstone23.blogspot.com.au Keep up the posts! Re: Who else is building with Eden Brae? 10996Dec 27, 2014 7:04 pm Hi all just wondering who has used the PGH Mocha Bricks for their home, if you could post up some pictures so we can get an example as we have seen some houses with Mocha and others with the Mocha look different. Thanks again all post much appreciated! Have a great weekend!! Building the Sheffield 25 + 2 sq Re: Who else is building with Eden Brae? 10997Dec 27, 2014 7:11 pm sheffieldhunter Hi all just wondering who has used the PGH Mocha Bricks for their home, if you could post up some pictures so we can get an example as we have seen some houses with Mocha and others with the Mocha look different. Thanks again all post much appreciated! Have a great weekend!! Where are you located? We went with Gravel which was a similar colour to the mocha from memory. Pgh gave us a list of all houses within our general area made with gravel bricks. You could ask then to give you a list for mocha. Re: Who else is building with Eden Brae? 10998Dec 27, 2014 8:09 pm kim_kdr sheffieldhunter Hi all just wondering who has used the PGH Mocha Bricks for their home, if you could post up some pictures so we can get an example as we have seen some houses with Mocha and others with the Mocha look different. Thanks again all post much appreciated! Have a great weekend!! Where are you located? We went with Gravel which was a similar colour to the mocha from memory. Pgh gave us a list of all houses within our general area made with gravel bricks. You could ask then to give you a list for mocha. Hi there we are located in the Hunter Region building in McKeachie's Run Aberglasslyn we have been the PGH bricks they did give us a list of some mocha brick built within our area location some look different to others which we don't understand maybe different batches, not sure we don't want to choose a brick and then once being laid it looking different would love to see others on here that have built with same or similar brick. Thanks Re: Who else is building with Eden Brae? 10999Dec 27, 2014 8:47 pm Hi all hope everyone had a wonderful Christmas!!! Just wanting to know if anyone knows what bricks are on the Eden Brae Livingstone & Sheffield out at the The Ponds display homes? All replies much appreciated!!! Thanks Building the Sheffield 25 + 2 sq Re: Who else is building with Eden Brae? 11000Dec 27, 2014 9:38 pm The Livingstone is 'Loam'. Not sure about the Sheffield though sorry. I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 22218 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223588 Thanks for your reply. I will just wait and see I guess. Trying to get some more information from our builder. 9 30235 |
